HELP: 96 ITR wheel bearing
Old Jul 7, 2008 | 10:52 AM
DBada FM's Avatar
Default HELP: 96 ITR wheel bearing
I recently just got my wheel hub pressed out so that i could replace the studs with extended ones. My question is, where can i buy new oem/replacement wheel bearings because i know its recommended that the wheel bearing is replaced once it is removed. Any help would be much appreciated, thanks.
Old Jul 7, 2008 | 11:42 AM
RagingAngel's Avatar
Default Re: HELP: 96 ITR wheel bearing (DBada FM)
IIRC, the front wheel bearings are all the same for the DC2s.
If they are not, I am almost positive the ones from the GS-R will work just fine as the 96spec had the smaller brakes.
Old Jul 7, 2008 | 12:25 PM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBada FM &raquo;</TD></TR><TR><TD CLASS="quote">. My question is, where can i buy new oem/replacement wheel bearings </TD></TR></TABLE>
Your local dealer will have them.
Old Jul 7, 2008 | 12:44 PM
Flexin5's Avatar
Default Re: HELP: 96 ITR wheel bearing (get RIGHT)
i just changed mine two days ago. for the ITR 4x114.3 setup you need a GSR wheel bearing, it's about $100-$150 from honda.
Old Jul 7, 2008 | 05:38 PM
DBada FM's Avatar
Default Re: HELP: 96 ITR wheel bearing (Flexin5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexin5 &raquo;</TD></TR><TR><TD CLASS="quote">i just changed mine two days ago. for the ITR 4x114.3 setup you need a GSR wheel bearing, it's about $100-$150 from honda. </TD></TR></TABLE>
thanks for the info, ill head to my local acura dealership and pick some up..
Another question: Where is a good place/site to buy brake rotors for ITR 4x114 setup. Im looking for a good deal
Old Jul 7, 2008 | 07:43 PM
BlueIntegraBoy's Avatar
Another question: Where is a good place/site to buy brake rotors for ITR 4x114 setup. Im looking for a good deal </TD></TR></TABLE>
PM BrakeExpert for redrilled rotors.
Old Jul 8, 2008 | 09:57 AM
DBada FM's Avatar
Default Re: HELP: 96 ITR wheel bearing (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
thank you sir
Old Jul 8, 2008 | 04:19 PM
Flexin5's Avatar
I just grab GSR rotors and re-drill them to 4x114.3 by a machine shop. i have a GSR theme going on..lol
Old Jul 8, 2008 | 05:25 PM
I AM WEASEL's Avatar
this is somewhat ot but does anyone know if the rear spindle is that same as the 98 spec 5 lug spindle? or is it like the non itr spindle?
Old Jul 8, 2008 | 06:58 PM
Flexin5's Avatar
Default Re: HELP: 96 ITR wheel bearing (-DC4-)
^my bet would be like the non-itr spindle, the 5bolt one may be slightly bigger than the 4x114.3.
Old Jul 9, 2008 | 03:10 AM
JOHN WAYNE's Avatar
I just grab GSR rotors and re-drill them to 4x114.3 by a machine shop. i have a GSR theme going on..lol </TD></TR></TABLE>
https://honda-tech.com/zero...age=1
i believe there is good info in here
Old Jul 9, 2008 | 12:12 PM
Flexin5's Avatar
Default Re: HELP: 96 ITR wheel bearing (JOHN WAYNE)
^Good link.
but just to clairify, accord 4x114.3 rotors and prelude 4x114.3 rotors are NOT a bolt up application. the rotor is bigger than the JDM ITR setup. you can use this rotor, however you will have to get a bracket that spaces out the caliper because you will be using a 11inch rotor and i beleive you have to use a prelude, accord or 5 bolt type R caliper. &lt;-- this is known as the "oem big brake upgrade"
now if you diden't want a bigger sized rotor, and wanted to use the calipers that came with the JDM ITR, then a GSR rotor (the same size) re-drilled to 4x114.3 will bolt up.
Modified by Flexin5 at 9:18 PM 7/9/2008
HaTa
Dec 10, 2006 07:49 AM
Jeff_B
Jul 9, 2004 11:28 AM
Wide Open Throttle
11
Mar 22, 2004 12:28 PM
92civeg
Feb 27, 2004 08:32 PM
TyPe_R_GuY
Nov 10, 2003 03:39 PM
