1986 instrument panel lights
The instrument panel lights on my 86 do not work. I was hoping it was just a fuse, but I checked the fuse block and there is no separate fuse just for the instrument panel lights. Am I going to have to pull the instrument cluster out to find the problem? Or is there something else I should check first. If I do have to pull the cluster off, is that a big deal?
Thanks in advance.
Thanks in advance.
I figured out why the instrument panel lights are out. The dashboard lower panel (right below the steering wheel) is missing. There is supposed to be a dashlight brightness control unit mounted on that panel, and that's gone too. I found the connector that should be plugged into the control unit shoved up amongst the wires. I have no idea why the previous owner would have removed this. Anyone know of a good place on the web to get classic honda parts? Otherwise I'll be visiting the junkyard this weekend.
Ryan559
Sep 6, 2013 02:39 PM
19cIvIc94
Jun 3, 2007 05:37 PM
Nural
Oct 25, 2006 08:00 AM
HondaHemi
May 12, 2005 09:05 PM
Mike36
Feb 26, 2003 08:14 AM
