crome tuned issue leans out at 5psi regardless of rpm
Old Jul 6, 2008 | 04:59 PM
27psi's Avatar
Default chrome tuned issue leans out at 5psi regardless of rpm
I'm in the process of tuning my turboed zc with chrome and for some reason at 5psi it wants to go instantly lean. I can partial throttle it to red line and have plenty of fuel as long as I keep it lower that 5 lbs.
Info:cut is set at 7800 rpm (built head) and launch control at 4200. I'm running rc 750s and a walbo 255. Gm 3 bar that worked in last setup.
I'm gonna try a different map sensor but if that doesn't work, other ideas would be appreciated. Also, boost cut is at 22lbs.
Old Jul 6, 2008 | 06:16 PM
98vtec's Avatar
moderator emeritus
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (27psi)
injector size?
plug gap?
what does your table timing look like?
how does the fuel curve look?
Old Jul 6, 2008 | 07:08 PM
mtber's Avatar
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (98vtec)
What impedance injectors ?
Are you running a resistor box ?
Old Jul 7, 2008 | 03:11 AM
27psi's Avatar
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (mtber)
750cc injectors with aresistor box. The whole setup was swaped from my ef hatch wich ran great. All I changed was converted to chrome from zdyne, built the head, different turbo, intake manifold and throttle body, and different resistor box. So it has to have somthing to do with chrome, resistor box, wiring or maybe a bad sensor. As far as the map, I used the core performance bin from xenocron, and made a few small adjustments to the low cam fuel table.
btw, if the plug gap was off, it would cause lack of spark wich would show rich on the wideband...right?
Old Jul 15, 2008 | 03:05 AM
dseriesdrag's Avatar
bump
Old Jul 15, 2008 | 08:13 AM
mtber's Avatar
Check your plug gap & get back to us.
Old Jul 15, 2008 | 01:52 PM
Tomdata's Avatar
email the .bin out of your ecu so I can check it out for you.
Old Jul 16, 2008 | 05:09 PM
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (Tomdata)
as far as the bin goes, I just started with the core performance bin off xenocron. and added fuel. up till 5 lbs it is very smooth. I've gone as far as bumping up to 100% duty cycle across the board in boost and still acts like it hitting fuel cut.
http://www.xenocron.com/bins/i...=Corr Performance TUNE d16y7.bi&directory=Crome/D-Series&
Old Jul 16, 2008 | 08:05 PM
mtber's Avatar
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (dseriesdrag)
Did you ever check your plug gap ?
Old Jul 17, 2008 | 02:56 AM
new ngks with stock gap. Im gonna try gapping them down today.
Old Jul 17, 2008 | 03:00 AM
btw I checked the fuel pressure and its at 78psi. Regulator is good and return line is clear. Could this cause a lean out? Any ideas on what causes high fp other that the regulator.
Old Jul 17, 2008 | 07:11 AM
Tomdata's Avatar
the duty cycle information in crome is garbage. Ignore it. Truth is that crome doesn't give you any way of knowing what the actual duty cycle is.
Old Jul 17, 2008 | 08:53 AM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseriesdrag &raquo;</TD></TR><TR><TD CLASS="quote">new ngks with stock gap. Im gonna try gapping them down today. </TD></TR></TABLE>
There is part of your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseriesdrag &raquo;</TD></TR><TR><TD CLASS="quote">btw I checked the fuel pressure and its at 78psi. Regulator is good and return line is clear. Could this cause a lean out? Any ideas on what causes high fp other that the regulator.</TD></TR></TABLE>
Here is another part of your problem, try a new gauge.
Old Jul 17, 2008 | 08:56 AM
98vtec's Avatar
moderator emeritus
word conan
go to .030 gap
Old Jul 18, 2008 | 03:06 AM
I gapped them down to 27 wich is what I had on my last setup. No luck.
Also, the guage is not the problem. I've tried two guages and a $400 matco fp tester. All are reading between 75 and 78psi at the filter banjo bolt.
Old Jul 18, 2008 | 11:11 AM
98vtec's Avatar
moderator emeritus
can you email me your bin file?
blakesvtec (at) yahoo.com
Old Jul 21, 2008 | 07:11 PM
alpha's Avatar
Wait ... What's your base fuel pressure?
Old Jul 21, 2008 | 07:19 PM
ralph11sec's Avatar
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (alpha)
how lean are we talking about here?
your fp is too high. it should be from 35-45 only.
injectors stack up at very high pressure.
Old Jul 27, 2008 | 01:00 PM
Default Re: chrome tuned issue leans out at 5psi regardless of rpm (ralph11sec)
problem solved. Washers from fuel line to fuel rail were switched. The copper washer was between the line and the bypass valve. Therefore, it was blocking fuel from the fuel rail and raising fuel pressure in front of the fuel rail. I'ts always somthing stupid, but I'm glad it was somthing cheap!
slob20ef
Mar 15, 2012 07:31 AM
John.CRX
May 21, 2010 10:48 AM
MantisX
Engine Management and Tuning
May 20, 2010 04:24 PM
2K_TEG
Jun 2, 2002 09:28 PM
