brake fade problems
Old Jul 6, 2008 | 03:10 PM
sohctodohc's Avatar
Default brake fade problems
this is a 94 civic ex non abs, rear disc conversion
new brake fluid
bled 3 times now
not loosing any fluid
so i swapped in rear disc with a 30/40 prop valve. bled the brakes. and was having problems when i was on a hill the brake pedal would start to fade and then i would pump it and it would hold pressure for a little longer.
so i swapped over to a early prelude mc that is 15/16 and im still having problems with the brake fade. in the next couple days im gonna get a brake bleeding machine and try that.
otherwise do you guys know why the brake pedal would be fading like this? what causes it usually? with a little pressure i can feel it fade almost to the floor
Old Jul 6, 2008 | 03:22 PM
count me out's Avatar
* B A N N E D *
Default Re: brake fade problems (sohctodohc)
brake fade is when the pads, rotors and fluid heats up and doesnt slow you down like it should.
your problem just sounds like you have a leak, a line is expanding or one of your seals, probably in your mc is bad.
Old Jul 6, 2008 | 03:25 PM
sohctodohc's Avatar
Default Re: brake fade problems (count me out)
might be the mc. but i cant imagine my old one goin bad and now the new one having a bad seal to.
when you put on a new mc do you have to bench bleed it??? cause i didnt.
also there is no leaks anywhere i have never once been low on fluid and the fluid in the system is brand new.
Old Jul 6, 2008 | 03:28 PM
* B A N N E D *
you can bench bleed it on the car, but yeah, you will put air into your system without bleeding it before hooking up the lines.
Old Jul 6, 2008 | 03:52 PM
sohctodohc's Avatar
how do you go about capping the ports off on the mc???
Old Jul 6, 2008 | 05:24 PM
* B A N N E D *
you dont cap them off when you bleed it. you need to get a bench bleed kit with comes with lines and nipples to screw into the mc line holes.
Old Jul 6, 2008 | 05:33 PM
sohctodohc's Avatar
ok i will check around town tomorrow to see what i can come up with,. thanks for the help
Jaydeep
Jun 25, 2012 09:25 PM
98GreenTegGSR
Dec 5, 2005 11:04 AM
viperguy
Jul 29, 2003 06:57 PM
dnt94civic
Jun 7, 2002 05:04 AM
