what gas to use in d16z6?
Old Jul 6, 2008 | 05:10 AM
redcoats1976's Avatar
Default what gas to use in d16z6?
in the owners manual it says premium.i have used 91 and 93 for years.the other day i tried using 89 with no noticeable problems.is this going to affect my motor or gas mileage,and if so,how?
Old Jul 6, 2008 | 05:20 AM
spivt11's Avatar
* B A N N E D *
Default Re: what gas to use in d16z6? (redcoats1976)
Lol its a Honda, regular unleaded will be just fine
Old Jul 6, 2008 | 06:08 AM
itsmejto's Avatar
Default Re: what gas to use in d16z6? (spivt11)
What makes you a better authority on gas octane over Mr. Honda's recomendations ?
If it states premium in the hand book, that's what it needs to run at it's best.
Now it may run fine on regular, but at what loss or expense ?
If "it's a honda and runs fine on regular" please explain.
Old Jul 6, 2008 | 06:19 AM
OMGWTFBBQ!'s Avatar
Whats the compression ratio of the Z6?
I seriously doubt you need to be running premium in a single cam.
Old Jul 6, 2008 | 06:25 AM
GYChris's Avatar
Default Re: (OMGWTFBBQ!)
my old z6 used to pop between shifts, when i had premium in it seemed to do it less, as opposed to 87
Old Jul 6, 2008 | 06:31 AM
OMGWTFBBQ!'s Avatar
backfiring is unused fuel entering the exhaust manifold and exploding, if thats happening then your tune was too rich, or your TPS was a bit slow.
All that matters is the Compression Ratio. If yours is high, like mine at 11.1:1, then yes, use premium. If its low, like 9:1, then just use regular. But I have no idea what the CR is for a stock D16Z6.
Old Jul 6, 2008 | 06:41 AM
BryanM.'s Avatar
Resident Gearhead
Owner's manual says to run premium?!?
The CR of the D16Z6 is 9.4:1, I doubt that it needs premium.
Modified by mcvtec at 11:14 AM 7/6/2008
Old Jul 6, 2008 | 06:48 AM
devney's Avatar
I'm sure it doesn't take premium...that sounds rediculous. I never used premium in my z6. No need.
Old Jul 6, 2008 | 07:12 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcoats1976 &raquo;</TD></TR><TR><TD CLASS="quote">in the owners manual it says premium.i have used 91 and 93 for years.the other day i tried using 89 with no noticeable problems.is this going to affect my motor or gas mileage,and if so,how?</TD></TR></TABLE>
What manual are you looking at?
I'm looking at the '94 del Sol manual right now and for the S and Si models it says to use nothing lower than 86. The VTEC (B16) model it says to use premium (91 or higher).
Old Jul 6, 2008 | 08:02 AM
so good...i can save about 20 cents a gallon.
Old Jul 6, 2008 | 08:36 AM
spivt11's Avatar
* B A N N E D *
Default Re: what gas to use in d16z6? (itsmejto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmejto &raquo;</TD></TR><TR><TD CLASS="quote">What makes you a better authority on gas octane over Mr. Honda's recomendations ?
If "it's a honda and runs fine on regular" please explain.</TD></TR></TABLE>
Haha you sound like a clown, nah I better stop... Look man I dont know any Honda D series motor that needs to run on premium, they are called econoboxs for a reason. I dont know what his manual says for sure but I havent seen any manual from a civic that says use premium. Lol and Mr. Honda is just a group of individuals, highly skilled engineers I have no doubt, but if you educate yourself enough your just as knowledgeable as them. Dont hold anybody above yourself, everyone (almost everyone) on h-t has the capabillity to be as knowledeable about their car as Mr. Honda
Old Jul 6, 2008 | 09:05 AM
BuiltforSin's Avatar
Pics of manual that says to use premium.
Old Jul 6, 2008 | 09:25 AM
BlackDeuceCoupe's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redcoats1976 &raquo;</TD></TR><TR><TD CLASS="quote">1) in the owners manual it says premium...
2) i have used 91 and 93 for years.the other day i tried using 89 with no noticeable problems...
3) is this going to affect my motor or gas mileage,and if so,how?</TD></TR></TABLE>
1) If that's the case (which I doubt) - that's just...
(a) To lay a 'guilt trip' on you.
(b) Make you *think* you have a high-performance motor.
2) Once ppl switch to 'regular' gas they never switch back, except when...
(a) They *feel* guilty for not following directions.
(b) They *think* there is a drop in performance.
3) No & no!
I'm running a B16A2 ('99 Si) and 'regular' unleaded works great - better than 'premium' as long as I use Top Tier gas (Chevron, Shell, etc).
My suggestion is to run Top Tier 'regular' gas in your D16Z6, but don't take my word for it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">"I personally use regular even though my owner's manual says you'll get better performance with premium," says Lewis Gibbs, consulting engineer and 45-year veteran at Chevron oil company. He's chairman of Technical Committee 7 on Fuels, part of the Society of Automotive Engineers (SAE) Fuels & Lubricants Council.</TD></TR></TABLE>
Gibbs knows gas!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">"I go back and forth, and I'm hard-pressed to notice whether there's regular or premium in the tank," says Jeff Jetter, principal chemist at Honda Research and Development Americas.</TD></TR></TABLE>
Jetter knows Hondas and drives an Acura designed for premium!
The only modern engines that should really need premium are those with superchargers, which force-feed fuel into the cylinders...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">"You're driving along and just tramp the gas and the knock sensor cannot sense the knock fast enough in some cases, because the supercharger boosts pressure so fast," says Bob Furey, chemist and fuels specialist at General Motors.</TD></TR></TABLE>
Furey knows domestics!
Old Jul 6, 2008 | 02:20 PM
OMGWTFBBQ!'s Avatar
I don't think I'd run regular in my engine, and I dont even have my supercharger yet.
Old Jul 6, 2008 | 02:26 PM
Syndacate's Avatar
You can run it 100% fine on 87 octane (regular). If it's mis-firing on a stock D16Z6 - then you have other problems, and it isn't because of what octane fuel you're running.
If you think you get more HP, better engine life, or better gas mileage by using premium in a 100% stock D16Z6, then you should be shot.
87 octane is 100% fine.
Old Jul 6, 2008 | 06:10 PM
EG_ian's Avatar
Im sure any octane grade will do just fine?
Old Jul 6, 2008 | 06:54 PM
jdmpower363's Avatar
in any d series 87 octane will infact be perfectly fine and that is all i would use and always have with the many d series ive had. b series tho.. thats different.
Old Jul 6, 2008 | 06:59 PM
riceburnerryan's Avatar
the only time i ever used premium was when i had my GSR in my coupe... i used the 89 octane once and my car would sputter and feel really boggy... other than that i have a mini me with a Y7 block and a Y8 head and i run shell or conoco regular gas...
Old Jul 6, 2008 | 07:45 PM
itsmejto's Avatar
if indeed the manual does say use premium, then I see nothing in this iffy, cuddah, wouldah, shuddah, replies that indicate otherwise. Maybe in a clapped out 200k engine to save a little money ....... but, pay now, pay later .... 9.4:1 may not be high by racing standards, but it's up there ............. after all, what yah all think the "knock sensor" is for anyways ....
Old Jul 6, 2008 | 07:53 PM
rSol93's Avatar
i put the lowest grade in my Del sol si and it runs fine.
Old Jul 6, 2008 | 08:59 PM
biggjerryc's Avatar
Default Re: (rSol93)
you need racing fuel in that motor.
Old Jul 6, 2008 | 09:32 PM
sorullo's Avatar
JAJAJA DUDE.. YOU DO NOT NEED PREMIUM ,,, YOU CAN PUT WATER ON YOUR TANK AND THAT ENGINE WILL GO EVEN FASTER.... I ALWAYS USED REGULAR.. ON MY Z6 AND NEVER HAD A PROBLEM.. Z6 ENGINES ARE THE BEST OF ALL SOCH ENGINES.. ...TAT.. MANUAL IS TO MAKE YOU SPEND MORE MONEY ON GAS.. YOU KNOW HOW BUS. IS!!
Old Jul 6, 2008 | 09:41 PM
roycivic92's Avatar
i used to run 91 and yes it does pop when the tune is rich. i now pump 89.
Old Jul 9, 2008 | 09:26 AM
Syndacate's Avatar
Default Re: (itsmejto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmejto &raquo;</TD></TR><TR><TD CLASS="quote">if indeed the manual does say use premium, then I see nothing in this iffy, cuddah, wouldah, shuddah, replies that indicate otherwise. Maybe in a clapped out 200k engine to save a little money ....... but, pay now, pay later .... 9.4:1 may not be high by racing standards, but it's up there ............. after all, what yah all think the "knock sensor" is for anyways .... </TD></TR></TABLE>
Shut up, putting 93 in a Z6 is absolutely uneccessary, you don't know what you're talking about. It's not "shoulda woulda coulda" answers - I've owned D series (both Z6 and Y8) or 3 or so years - always put 87 in it, never had a problem with it.
"After all, what ya all think the knock sensor is for.."
I don't even think there is a knock sensor in Z6's OR Y8's...
Old Jul 9, 2008 | 09:33 AM
OMGWTFBBQ!'s Avatar
Y8s do have a knock sensor. Not sure about the Z6.
