Skunk2 Pro s Coilover question!
Old Jul 5, 2008 | 11:40 PM
jdmej814's Avatar
Default Skunk2 Pro s Coilover question!
Hey,
I have ej1 (eg coupe) Skunk2 pro series full coilovers,
Will they fit in an ek with just washers?
or do i need something more?
thanx
Old Jul 6, 2008 | 12:22 AM
jdmej814's Avatar
Default Re: Skunk2 Pro s Coilover question! (jdmej814)
..?? 13 views and nobody?
Old Jul 6, 2008 | 12:38 AM
hotrod99's Avatar
no it will not work if those are full coilovers
Old Jul 6, 2008 | 01:10 AM
junkspeedproject's Avatar
Default Re: Skunk2 Pro s Coilover question! (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">no it will not work if those are full coilovers</TD></TR></TABLE>
uhhh says who? yes they will fit. fronts are direct fit. rears fit with the use of washers. it will not work vice versa (ek to eg) without modification to your bushings.
Old Jul 6, 2008 | 06:22 AM
hotrod99's Avatar
Default Re: Skunk2 Pro s Coilover question! (junkspeedproject)
hmm...i was told that full coilovers would not fit but the sleeve and coil type coilovers would fit
Old Jul 7, 2008 | 02:12 PM
jdmej814's Avatar
o alrite wahsers?
how big should the washers be and how many do i need for each side?
Old Jul 7, 2008 | 03:06 PM
xjosfx's Avatar
I LIVE IN
dc lca's into ek?
Old Jul 7, 2008 | 09:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmej814 &raquo;</TD></TR><TR><TD CLASS="quote">o alrite wahsers?
how big should the washers be and how many do i need for each side?</TD></TR></TABLE>
i just used random washers i had laying around. the washer should be big enough to put the bolt through. buy a bag of washers and see how many you need to fill the gap. id say you have to fill in about an inch and 1/2 of gap so around 3/4" on each side of the lca. hope that helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">hmm...i was told that full coilovers would not fit but the sleeve and coil type coilovers would fit</TD></TR></TABLE>
never know till you try it! i just put some omni full coilovers on my 99 hatch from an ej1 so i can vouch that full coilovers work
Old Jul 12, 2008 | 12:12 AM
jdmej814's Avatar
kool kool, just put the coils on today.
i ended up gettin the washers that skunk give you for the ek from my boy. ...thanx for the help guys!
fst teg 1
Aug 26, 2004 09:31 AM
ieatrice
Aug 2, 2004 09:01 AM
ahh sanga
May 11, 2004 07:56 PM
Nocturnal
Sep 24, 2003 08:56 PM
akaEsCo01
11
Sep 6, 2003 04:08 AM
