Problem Starting Car! (94' Honda Civic EX)
Old Jul 5, 2008 | 10:58 PM
darithS's Avatar
Default Problem Starting Car! (94' Honda Civic EX)
My car won't start at all, there's still power from the battery, and the starter still spins, but the motor won't run, what would be the problem? Please help thanks
Old Jul 5, 2008 | 11:11 PM
Joon Joon's Avatar
Default Re: Problem Starting Car! (darithS)
does the fuel pump prime??
Old Jul 6, 2008 | 12:46 AM
nasteawhun's Avatar
Default Re: Problem Starting Car! (Joon Joon)
always remember, a car need only two things to start. fuel and spark. check if you have those, if you do, repost and well see what we can do...
Old Jul 6, 2008 | 12:58 AM
darithS's Avatar
Default Re: Problem Starting Car! (nasteawhun)
Alright, i'll check in the morning
Old Jul 6, 2008 | 01:32 AM
4drkidd's Avatar
Do it now...
Old Jul 6, 2008 | 01:33 AM
darithS's Avatar
Default Re: (4drkidd)
lol, it's dark and im tired
Old Jul 6, 2008 | 07:24 AM
THE GUY's Avatar
Not to be confused with "THE MAN"
Default FV-QR
Did you check to see if there is fuel and spark yet?
Old Jul 6, 2008 | 07:34 AM
JDMPHILEP91's Avatar
Default Re: FV-QR (THE GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GUY &raquo;</TD></TR><TR><TD CLASS="quote">Did you check to see if there is fuel and spark yet?</TD></TR></TABLE>
And If You Are Not Getting Fuel, Then Check Your Main Relay.
Old Jul 6, 2008 | 08:10 AM
.kyle's Avatar
Default Re: (darithS)
definitely a relay. turn the key to the second click. if you dont hear the fuel pump prime its the main relay, located above your hood release, little grey box. .
Old Jul 6, 2008 | 08:19 AM
zuruk's Avatar
you could always pull off the return from the fuel rail to see if fuel is going through
Old Jul 6, 2008 | 04:24 PM
slotec's Avatar
Default Re: (zuruk)
check these things to start a car. Fuel (Fuel and Fuel pressure), Spark (Spark Plugs), Main Relay, Compression, timging(Ignition & Timing Belt),and Power(Battery). Thats all I can really think of
Old Jul 7, 2008 | 08:30 AM
Joon Joon's Avatar
Default Re: (slotec)
yup but easy things first.. fuel and spark and check the grounds... then look at timing and compression..
Old Jul 7, 2008 | 08:57 AM
M3Vert's Avatar
Default Re: (Joon Joon)
my timing tensioner is creating a problem right now ... b18a1 gotta reset it that was OT BUT!
its most likely your main relay
or ecu fuse
Old Jul 7, 2008 | 10:17 AM
darithS's Avatar
Default Re: (M3Vert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .kyle &raquo;</TD></TR><TR><TD CLASS="quote">definitely a relay. turn the key to the second click. if you dont hear the fuel pump prime its the main relay, located above your hood release, little grey box. . </TD></TR></TABLE>
I can hear the prime when I turn the key, I think it has to do with spark, I'm going to check right now, get back to you guys later today, thanks for all the help
Old Jul 9, 2008 | 06:44 PM
darithS's Avatar
It is the distributor, I need a new one, can't afford one so I think i'll rebuild this one, can I use parts from any d-series distributor?
Old Jul 9, 2008 | 06:45 PM
rSol93's Avatar
possibly your coil or ICM
Old Jul 9, 2008 | 08:46 PM
slotec's Avatar
Default Re: (rSol93)
yea d series internals will work. Just replace the coil and ignitor inside the distributor and make sure you put the key in the cam the right way and not 180 degrees out.
Old Jul 9, 2008 | 08:47 PM
slotec's Avatar
also just double check your firing order, could possibly be off
Old Jul 9, 2008 | 10:02 PM
Joon Joon's Avatar
u sure its the distributor?? could be just ur wires or just the coil... and like i said check grounds..
Old Jul 9, 2008 | 10:08 PM
darithS's Avatar
Yeah we checked for spark from the spark plug wires, and there was none
Old Jul 10, 2008 | 04:49 AM
Joon Joon's Avatar
might be the coil..
Old Jul 10, 2008 | 07:07 AM
slotec's Avatar
something as simple as a thermostat ground or tranny ground will cause it not to start as joon mentioned
Old Jul 11, 2008 | 08:17 PM
happycorey's Avatar
If it started before and you didn't touch it it won't be a ground, or his firing order, it could be your distributor, and it could also be an ECU fuse, check that
Old Jul 11, 2008 | 09:00 PM
turkeyslow's Avatar
For a engine to start you actually need fuel, spark, compression, and AIR. I know its not a common problem, but you should varify your engine can actually breathe, just cause ya never know.
95PreludeNAed
Jan 10, 2012 04:09 PM
turboteg7
Dec 21, 2008 11:12 AM
evoalf
Sep 4, 2004 06:21 AM
msvara
Jul 30, 2004 10:32 PM
MADEinJAPAN
Sep 27, 2003 09:36 PM
