ZC Won't start has fuel but no spark.
Old Jul 5, 2008 | 09:35 PM
TNTNight's Avatar
Default ZC Won't start has fuel but no spark.
Hey I have a sohc zc in a 89 crx. It has fuel but no spark to the plugs. I have a new dis. with all the fixin's but still no spark. Can't figure it out. No codes no bad fuses but a really messed up wiring job. It just one day wouldn't start. Any help would be greatly appreciated. thanks
Old Jul 6, 2008 | 07:20 AM
hotrod99's Avatar
Default Re: ZC Won't start has fuel but no spark. (TNTNight)
Its could be your coil or ignitor inside the distributor
Old Jul 6, 2008 | 07:30 AM
TNTNight's Avatar
It's all new. The entire distributor and all the insides and out sides. It has new magnacor 9.5mm wires and everything. I took a spark plug out and tried to get it to spark a gap on a ground but nothing.
Old Jul 6, 2008 | 07:58 AM
hotrod99's Avatar
Default Re: (TNTNight)
make sure your getting 12v to the dizzy,also check the ground wire to the thermostat housing and also check the main relay
Old Jul 6, 2008 | 10:41 AM
slow88crx's Avatar
if it ran before and then just randomly stopped and everything else is new you prob just knocked a ground wire loose some where.
jonina
20
Oct 8, 2011 09:57 AM
IP RACING
Jan 15, 2007 07:10 PM
hondaboy90
24
Oct 29, 2006 06:38 PM
poopycar
Nov 2, 2004 11:26 AM
juanb
May 30, 2004 05:54 PM
