et for b18c5 equipped 4 dr
Old Jul 19, 2002 | 07:15 AM
blacks2000's Avatar
Default et for b18c5 equipped 4 dr
What do you guys think a 4 door gsr with a b18c5 dropped in with I/h/e will run? Thanks in advance...
Old Jul 19, 2002 | 08:01 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: et for b18c5 equipped 4 dr (slowhitels)
it's only 100 lbs more than a 2 dr. but IMO there's a better way to spent the money (even if it is an LS)... it goes like this: PSSSSSSSSSSSSSS
Old Jul 19, 2002 | 08:05 AM
blacks2000's Avatar
Default Re: et for b18c5 equipped 4 dr (dLo GSR)
CHeck my post in the ITR forum named "Am I crazy".
Old Jul 19, 2002 | 08:19 AM
fiebru1119's Avatar
should be in high 14's-low 15's considering it only 100 lbs heavier..
Old Jul 19, 2002 | 08:25 AM
blacks2000's Avatar
Default Re: et for b18c5 equipped 4 dr (fiebru1119)
really? I thought it would be quicker than that
Old Jul 19, 2002 | 08:36 AM
fiebru1119's Avatar
well, thats what stock ITR's are running where i live.. once in a while one will hit a 14.4 or 14.5.. but we've got a pretty shitty strip. check out what ITRs are running in your area and add a tenth or two to those ETs
Old Jul 19, 2002 | 10:43 AM
shadowdawn's Avatar
Well it won't be unless you strip it.... Your car is NOT a type r even with a type r motor in it, don't forget that. Besides turbo nets you WAY more power on your motor you have already and it cost about the same $5000 a jdm typer motor would cost you anyways... however if your getting this motor less then $3000 then its not such a bad deal, assuming someone's doing the swap for free
Old Jul 19, 2002 | 10:57 AM
blacks2000's Avatar
Default Re: et for b18c5 equipped 4 dr (shadowdawn)
I'm getting it a shitload cheaper than that. Already in the car. 11k for a 97 gsr sedan with 35,ooo on the chasis and just under 40, ooo on the engine.
Konigretracts
12
Nov 17, 2012 02:03 PM
silensmortalis
Jul 8, 2009 01:04 AM
hlee5363
28
May 9, 2008 02:03 AM
B20VTEC-DC
17
Feb 6, 2004 06:07 PM
slimbo
May 28, 2003 09:09 AM
