is there any other way to power a fuel pump
Old Jul 4, 2008 | 12:59 PM
crxnatic's Avatar
Default is there any other way to power a fuel pump
is there any other way to power a fuel pump. im having problems with the fuel pum it does not want to go on i tested is good new main relay and nothing happens can i use another way of powering the fuel pmp like for example a switch?
Old Jul 5, 2008 | 02:58 AM
JKGONZALEZ3's Avatar
Default Re: is there any other way to power a fuel pump (crxnatic)
are you trying to steal a car??
have you tested the fuel pump to see if that works?
Old Jul 5, 2008 | 07:47 AM
re_X_si's Avatar
rewire your fuel pump
Old Jul 5, 2008 | 08:04 AM
HondaHeddie's Avatar
do you get voltage at the connector at the fuel gauge sensor? (under the rear cargo box)
if you do not get voltage at that connector as soon as you turn the key to RUN then check your jumper connector.
I have seen this often cause no pumping.
the jumper connector is taped up in the harness just to the left of the clutch pedal.
it is brownish orange and flat (20pin I think). take it off and make sure it is clean. you may need to connect/disconnect a few times to get it clean
NOTE:
This is not an in-line connector, it is a connector with a cap on it. The cap completes the circuit for alot of different areas.
in the schematics it is C403 (pic 35 in the helms manuals)
This connector will catch moisture and corrode. Since it is at the center of alot of circuits, any poor connection will soon be a problem and with the age CRX's have on them it is not surprising that some will be tired
pappasmurf
Nov 11, 2024 07:43 AM
carracr625
Apr 19, 2019 06:29 AM
Matthew Mullery
Honda Civic (2006 - 2015)
Feb 25, 2017 09:37 PM
NovaRex
Dec 4, 2015 05:10 PM
civic28
Mar 26, 2014 04:18 PM
