need to lower cbr 600 f4i
Old Jul 4, 2008 | 11:19 AM
yerlyg's Avatar
Default need to lower cbr 600 f4i
does anyone know how to lowere a cbr 600 f4i i've had it for over 6 months now and i dont want to buy those lowering links cause i've heard that they change the bike's handling does nyonw have a link were i can buy some sort of a shaved seat or a corbin seat thanks alot
TOO MUCH BLOOD NOT ENOUGH ALCOHOL
CBR F4I 06
Old Jul 4, 2008 | 11:46 AM
ucb's Avatar
ucb
Default Re: need to lower cbr 600 f4i (yerlyg)
did you tip it over or something?
Old Jul 4, 2008 | 03:23 PM
sup gurl's Avatar
JUST TAKE OFF THE SEAT AND USE A PLANK OF WOOD/SWATCH OF FOAM
Old Jul 4, 2008 | 03:30 PM
Tornadom's Avatar
Remove the seat from the bike, flip it over and start peeling the fabric from the seat base. After you have the vinyl off of the base, cut the foam so that it is thinner and then reattatch the vinyl to the base/foam.
Old Jul 4, 2008 | 03:32 PM
rd91sib18c5r's Avatar
Get the links and lower the front using the triple clamps, should still handle
good but you can't lean over as far.
Old Jul 4, 2008 | 04:23 PM
silentballer's Avatar
Take the seat off. Take off the vinyl/leather seat covering (probably held in place by staples). Take off the foam. Now buy yourself a nice big piece of gel (I don't remember the website that offers big pieces but I'm sure you can find it). Cut it to the shape of the plastic frame for your seat and glue it on. Reattach the seat cover and voila - you have a seat that's probably an inch to an inch and a half lower and still extremely comfortable.
EDIT: Found the website that goes into detail of the above process (includes websites for you to buy the materials)
http://www.itrocks.com/motorcycles/gel_seat.htm
Old Jul 8, 2008 | 06:21 PM
yerlyg's Avatar
thanks silent baller that is a pretty good site ima try it to see if it works that gel seat seems pretty comfortable
Old Jul 8, 2008 | 06:22 PM
yerlyg's Avatar
Default Re: (sup gurl)
i almost drop it but good think i had some frame sliders installed because i knew that was probably gona happen
Old Jul 8, 2008 | 06:24 PM
yerlyg's Avatar
Default Re: need to lower cbr 600 f4i (rd91sib18c5r)
i tried that but when i put the vynil back and then i sit on it it leaves athat extra space that was there
Old Jul 8, 2008 | 09:14 PM
CblP s40's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yerlyg &raquo;</TD></TR><TR><TD CLASS="quote">i tried that but when i put the vynil back and then i sit on it it leaves athat extra space that was there </TD></TR></TABLE>
What?
Old Mar 6, 2014 | 09:55 AM
eytrix's Avatar
i lowered my handlebars by 2 inches via the triple clamps in order to achieve a more aggressive riding position and less of a tendency to lift up. you can also dial in your rear shock to meet a more specific weight (in doing so, you need to pay attention to carrying people). If you need to lower because you arent touching the ground, thats a different story. You can get lowering links, but be aware that this drastically effects your ground clearance, turn degree, and lean angle. Honestly, the best bike i had, only my toes would touch the ground sitting at the rear of the seat; i like it better that way. with my cbr6 f4i, i can plant my feet at any position.
Old Mar 6, 2014 | 11:43 AM
MSchu's Avatar
My Name is Nobody
This thread is four years old...
TypRice
Honda Motorcycles
16
May 23, 2009 10:39 AM
AnDThEnWuT
Honda Motorcycles
16
Nov 11, 2008 09:48 AM
AdeJong 03
Honda Motorcycles
26
Jun 16, 2006 04:18 PM
CBennyR600RR
Honda Motorcycles
Oct 23, 2005 04:51 AM
ScareyH22A
Honda Motorcycles
Apr 27, 2005 03:39 PM
