Need help plz....axel/hub noise driving me crazy
Old Jul 4, 2008 | 09:40 AM
crxsleeper210's Avatar
Default Need help plz....axel/hub noise driving me crazy
ok i have replaced my hub bearing, my halfshaft bearing and my axel and im still hearing a noise coming from my driver side axel...it sounds like a grinding noise and it only happens when the car is under load and it gets worse the faster i go. could it be my hub? this has never happened before ..usually i just replace an axel or a bearing and its fine...me and my friend are stumped and its driving me crazy...any suggestions are welcome...thanks
Old Jul 4, 2008 | 09:56 AM
hotrod99's Avatar
Default Re: Need help plz....axel/hub noise driving me crazy (crxsleeper210)
my buddy had the same problem and it ended up being the dust cover behind the rotor
Old Jul 4, 2008 | 10:15 AM
Default Re: Need help plz....axel/hub noise driving me crazy (hotrod99)
well i dont think its that because doesn't the dust cover just sound like a scraping noise? ive had the happen too but this sounds like something is loose or something is grinding hard.
Old Jul 4, 2008 | 10:49 AM
mcj_420's Avatar
i dont know but do you think it could be your brake pads grinding against your rotor, thats what mine dose, i already bought the brakes i just need new rotors. try just jacking the car up and turning the tire
Old Jul 4, 2008 | 11:00 AM
Default Re: Need help plz....axel/hub noise driving me crazy (mcj_420)
ok its not the pads or rotors...all pads and rotors around are new out of the box....pads and rotors have literaly 3 or less miles on them...the wheel is mounted securely and its not lopsided...all tires are brand new 3 or less miles on them. suspension is brand new koni/gc less than 3 miles on it......innovative traction bar brand new.....skunk2 uca's brand new......i am stumped
Old Jul 4, 2008 | 11:02 AM
let me re-phrase the sound it sounds like a "thumping" noise.... like thump thump thump when i accelerate
Old Jul 4, 2008 | 12:03 PM
hotrod99's Avatar
are u 100% sure the axle is in all the way?
Old Jul 4, 2008 | 06:41 PM
i guess that is a something i will check tomorrow and post the results...if not that any other suggestions
Old Jul 5, 2008 | 11:27 AM
ok im 100 percent the axel is in all the way....and its a new rebuilt one i just bought today....what else could it be.
Old Jul 18, 2008 | 03:37 PM
beige89civic's Avatar
* B A N N E D *
Is your tire out of round? Did you buy a cheap axle?
Old Jul 18, 2008 | 03:41 PM
Default Re: Need help plz....axel/hub noise driving me crazy (beige89civic)
i found out what it was...the bearing was not properly installed into the hub and the retaining clip wasnt on...the tire is brand new and the axel was custom made. The shop has since replaced with a new bearing and clip....all is well again
Old Jul 21, 2008 | 07:41 PM
* B A N N E D *
NIce
bestofthe80s
Jul 9, 2017 01:29 PM
project_EG9
Nov 30, 2012 04:57 AM
h23vtak
Sep 24, 2006 09:47 AM
Knightmare69
Sep 11, 2006 09:07 AM
jaydm ferio
Jan 23, 2006 07:42 PM
