Damn Leaks!!!
Old Jul 19, 2002 | 05:07 AM
MyWhiteCivic's Avatar
Default Damn Leaks!!!
Can someone help me. I'm having a problem with leaking oil and exhaust. Let me start on the oil leak then I will explain the exhaust leak. The oil leak is coming from the back of the block. Now I believe it's coming from the oil feed line but I'm not certian. I don't want to over tighten the sending unit nuts because I did that before and split it in half. Can I just put silicon over all the seals to get it to work? Now on to the exhaust leak... my exhaust is leaking from the top of the downpipe (where it meets the compressor). I put all the bolts in there and tightened them up but it still leaks. Should I have a gasket in there because my kit didn't come with one? Thanks!
Old Jul 19, 2002 | 05:28 AM
CovertFI's Avatar
Default Re: Damn Leaks!!! (MyWhiteCivic)
for the oil leaks. are you using teflon tape? if so that is your problem. use the red rtv sealent, works like a charm.
are you positive it is leaking from the outlet flange on the turbo. do you see the soot or feel the exhaust?
Old Jul 19, 2002 | 05:34 AM
Default Re: Damn Leaks!!! (CovertFI)
Yeah I am using teflon tape on the fittings. My friend who helped me used it on his setup and it didn't leak at all but on mine, it leaks a little. Where should I go to pick up some of that Red RTV Sealent? And should I take out all the teflon tape and use this stuff instead or just put this stuff around the seals?
About the exhaust... I can feel it coming out from around the flange.
Old Jul 19, 2002 | 06:54 AM
b18b98's Avatar
What I did was put some teflon tape on the fitting and some hondabond.
Old Jul 19, 2002 | 07:13 AM
CovertFI's Avatar
remove all of the teflon and put the rtv on the threads and then just screw them in. it fixed all of my leaks
Old Jul 19, 2002 | 07:27 AM
Where did you buy the rtv from?
Old Jul 19, 2002 | 07:28 AM
Default Re: Damn Leaks!!! (b18b98)
did you put the hondabond on all the fittings?
Old Jul 19, 2002 | 08:13 AM
tararan's Avatar
yeah i got leak too.. but i think its the oil pan.... i replaced the sealant and gasket and still have a lil leak.. damn i broke one of the stud tightening the oil pan back. didnt seem like it was coming from the oil sending unit.. but i just check the oil level all the time...
Old Jul 19, 2002 | 10:38 AM
SIK IN DA HED's Avatar
New User
Default Re: Damn Leaks!!! (tararan)
im not surprised if your oil pan is leaking. i still have an oil leak to this day after hours of puttin jb weld on it. the leaks are minor, but a leak is STILL a leak. slap a gasket between the flanges to get rid of the exhaust leak.
Old Jul 19, 2002 | 12:01 PM
Default Re: Damn Leaks!!! (dlplayboy)
Do you know where I can get an exhaust gasket like that?
Mag00n
May 9, 2004 10:28 AM
jdmcivicdx
Feb 11, 2004 08:12 PM
Jdm_Rice_Monster
Nov 23, 2002 04:52 AM
