HowTo: Install 88-89 EDM MPH cluster in 88-89 CRX/Civic
Hello honda-tech
Heres the directions on how to install that elusive 88-89 EDM MPH gauge cluster into an 88-89 EF
Updated 7/3/08 10:43PM PST
Rev. 0.2-A
--------------------- added visual aids
--------------------------------- ] numbered wires
--------------------------------- ] ascii art illustration of plug(s)
--------------------- grammar correction
Updated 7/3/08 10:30PM PST
Rev. 0.2
---------------------- VSS wiring corrections
---------------------- pics no longer show correct wiring
---------------------- cel/oil light wiring corrections
---------------------- hatch open wiring corrections
---------------------- seatbelt warning wiring corrections
--------------------------------- ]wired to hazard light on cluster
----------------------------------(this would be a good shiftlight/vtec light)?
Rev. 0.2
[INTRO]
I wanted to install the 150mph EDM cluster for the 88-89, but I could not find information on this anywhere!
All the howto's were for the clusters in km/h or for the 90-91.
So heres the howto.
This task was accomplished by tracing the pcb layout on the original cluster, and matching to the pins on the new cluster.
[NO WIRE CUTTING REQUIRED
Assuming that everyone is familiar with removing their gauge cluster; All I'm going to give is the correct pin-outs.
You can de-pin the plugs with a micro flat blade screwdriver through insertion in the front of the plug where attachment to the cluster is established and gently prying up the plastic clip inside of the plug.
(blurry pics at bottom) -- OUTDATED DO NOT USE AS REFERENCE
These pin-outs are left to right with the tab facing up from the side the wires enter the plug from the vehicle
________|--------|________
| 1 2 3 4 5 [] 7 8 9 10 11 12|
[12 PIN]
1. green/blue
2. yellow
3. yellow/white
4. green/orange
5. yellow/red
6. [--blank--]
7. red/black
8. white/blue
9. black/yellow
10. blue
11. red
12. yellow/green
____|------ |____
| 1 2 [] 4 5 6 7 8 |
[8 PIN]
1. green/yellow
2. yellow/red
3. [--blank--]
4. green/red
5. black
6. blue/yellow
7. green/black
8. red/blue
[TO GET FULL BRIGHTNESS ON YOUR GAUGE CLUSTER] -- THIS PART IS IMPORTANT...
1. de-pin your dimmer switch
2. cross red/black wires together
(you can slide them into each other and wrap them with electrical tape no cutting required)
NOTES: There is no dimmer on the EDM clusters, if someone knows how to implement this function please post a reply. Your dimmer will not function with this cluster.
WARNINGS:
1. If you do NOT do this your gauge cluster will not be fully illuminated.
2. If you adjust your dimmer switch without making this modification the cluster WILL go crazy if the brightness is turned down. All lights will illuminate and the gauges will go to 100%. This probably isnt healthy for it.
[STOCK WIRING FOR 89 CRX HF WITH TACH]:
____|------ |____
| 1 2 3 4 5 [] 7 8 |
[8 PIN]
1. black
2. red/blue
3. green/black
4. green/red
5. yellow/red
6. [---blank---]
7. blue/yellow
8. green/yellow
| 1 2 3 4 5 6 7 [] 9 10 11 12|
[12 PIN]
1. blue/green
2. yellow
3. yellow/white
4. yellow/red
5. green/orange
6. red/black
7. red
8. [---blank---]
9. black/yellow
10. white/blue
blue
yellow/green
[PICTURES]
---all pictures are outdated. -- DO NOT USE FOR WIRING REFERENCE
Modified by opt1k at 10:59 PM 7/3/2008
Modified by opt1k at 1:52 AM 7/4/2008
Heres the directions on how to install that elusive 88-89 EDM MPH gauge cluster into an 88-89 EF Updated 7/3/08 10:43PM PST
Rev. 0.2-A
Rev. 0.2
Rev. 0.2
[INTRO]
So heres the howto.
]Assuming that everyone is familiar with removing their gauge cluster; All I'm going to give is the correct pin-outs.
[12 PIN]
1. green/blue
2. yellow
3. yellow/white
4. green/orange
5. yellow/red
6. [--blank--]
7. red/black
8. white/blue
9. black/yellow
10. blue
11. red
12. yellow/green
____|------ |____
| 1 2 [] 4 5 6 7 8 |
[8 PIN]
1. green/yellow
2. yellow/red
3. [--blank--]
4. green/red
5. black
6. blue/yellow
7. green/black
8. red/blue
WARNINGS:
____|------ |____
| 1 2 3 4 5 [] 7 8 |
[8 PIN]
1. black
2. red/blue
3. green/black
4. green/red
5. yellow/red
6. [---blank---]
7. blue/yellow
8. green/yellow
[12 PIN]
1. blue/green
2. yellow
3. yellow/white
4. yellow/red
5. green/orange
6. red/black
7. red
8. [---blank---]
9. black/yellow
10. white/blue
blue
yellow/green
[PICTURES]
I used the tachometer and speedometer from a UKDM cluster and installed them into a USDM cluster, just a matter of unscrewing from the bhttps://honda-tech.com/attachment.php?attachmentid=43293&stc=1&d=12437831 85ackside.
same here i did this with a 90 style cluster, just swap the gauges onto my usdm cluster and i was good to go.
Here is my problem. The reason I want to swap over my cluster is because My 88 Si cluster is burnt up on the back side so I dont have any cluster lights. I may buy both and just swap over everything from the ukdm cluster to a other Si cluster. What would you guys think? Here is my picture of the cluster
Swapping the housings will not work for the 88-89.
I already attempted this. The housing internals are completely different.
This may not be the case for the 90-91 cluster.
I dont know, I dont have one.
This writeup is for an 88-89 HF cluster to an 88-89 UKDM cluster
Please be aware of that
Hello, i hate re bumping a thread so old and i do apologize.
im having an issue with the wiring, i`ve been able to rewire almost everything, only missing the seat belt reminder, and the vss, (CEL code thrown).
the issue being that the pin outs seen in the internet doesnt match, what i have, been doing trial and error, but at 1 point, smoke came from cluster, so i suppose cable was in a real wrong position, does any one has the correct pics with the repining done,
i have the pics of the connector before repining them.
hope to have some help thanks.
http://imageshack.us/photo/my-images...4052012088.jpg
http://imageshack.us/photo/my-images...052012083.jpg/
KevinEF7
13
Jul 26, 2013 10:35 PM
I8ayellowcrayon
Apr 18, 2007 02:16 PM
