HOW hard do i have to shake it-------tranny(get ur mind out the gutter)lol
so i decided to replaced clutch on my 1992 civic si and i cant get the tranny off..... i yank it and shimmy it still wont get off.... anyone recomend the best way to take it off..............well i replace the clutch on my 1991 accord before and it just slide off... maybe its because hydraulics and cable makes any difference. thanks so much
Well you can shake it as much as you want but it might hurt!
May be a dumb question but are you sure you have all the bolts out?
if so the best thing I can tell you is just try to lift up on it while you are pulling and if you can get a couple of prybars inbetween tranny and engine then try that. sometimes input shaft can get stuck in the pilot bearing and make it hard to remove but just keep trying.
ok..... illl try to raise the tranny side up...........seriously from 8 am yesterday.... until 8pm cant get it out......next thing i know my back hurts like a CDL ran over me..hahaha
flywheel cover off?
and like everyone said, bolts all removed? bet they arent.
and like posted, jacking up the far end will usually seperate it enough to wedge something in there, use something plastic to avoid scratching it.
All the bolts aren't out. Got the ones around the inspection plate? Got the one right above midshaft/drivers side shaft hole for the tranny that goes from the block into the tranny? NOT the tranny rear bracket bolts, look a little more "forward" right above the shaft hole.
Get the ones right around the front mount, if you have one? How about the bolt there that goes block -> tranny.
serious
23
Nov 30, 2006 09:33 PM
