Polyurethane ITR shock bushings
Old Jul 18, 2002 | 08:06 PM
Vitt1's Avatar
Default Polyurethane ITR shock bushings
Have any of you ITR owners put Prothane or ES poly shock bushings on your car?
I have a GSR and bought some ITR shocks for the car. So I figured I'll put on poly bushings as well.
But when I contacted a suspension shop and asked for ITR shock bushings, they told me Prothane doesn't have them listed, so they're not available. Wouldn't those bushing sbe the same for both cars? If you have them, do you happen to have a part #? TIA
Old Jul 18, 2002 | 08:20 PM
ITR#132's Avatar
Default Re: Polyurethane ITR shock bushings (Vitt1)
The rear shocks are different between gsr and itr, the front shocks are the same.
Old Jul 18, 2002 | 09:15 PM
Warren's Avatar
Wrong-Way Wang
Do you mean the bushings at the shock hat? Don't get polys. They are SOFTER than the stock ones. The stock ones are rubber coated metal bushings.
Warren
Old Jul 18, 2002 | 09:17 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Polyurethane ITR shock bushings (Warren)
Warren, you amaze me with your knowledge.
Old Jul 18, 2002 | 09:46 PM
Vitt1's Avatar
Thanks for the reply and the tip about the stock one being stiffer. I don't know how to post a pic, but I am talking about #8 (top and bottom) on the pic on this link. If the link below doesn't work I'll try to figure out how to post the picture.
http://www.acuraautomotiveparts.net/...SHOCK+ABSORBER
Old Jul 18, 2002 | 10:05 PM
Warren's Avatar
Wrong-Way Wang
Yeah. Those are the ones. I have a full ES poly kit that I use for other bits and pieces. The stock versions are quite a bit harder than the poly ones. The only bad thing about the stockers is that they need to be drilled out for some shocks, like Konis.
Warren
Old Jul 18, 2002 | 10:44 PM
Vitt1's Avatar
Really glad I asked! Yeah, I agree, your knowledge is invaluable. I assume when you say the stock ones you are talking about the ITR, and they have to be stiffer than the GSR, right?
Old Jul 18, 2002 | 11:03 PM
type r 01-1063's Avatar
hmm..interesting.
So how about the shift linkage bushings? does the stock ITR have bushings better than Prothane Shift Linkage Bushings?
Old Jul 18, 2002 | 11:20 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Polyurethane ITR shock bushings (type r 01-1063)
The ES shifter bushings are stiffer than stock ITR bushings.
Yes, I was referring to ITR shock bushings.
Warren
Old Jul 18, 2002 | 11:39 PM
I meant the shift linkage bushings.
type r 01-1063 - who just ordered prothane shift linkage bushings for his type r.
Old Jul 19, 2002 | 05:01 AM
Asahi's Avatar
Warren how are those rubber coated metal? THey are easily compressible. THey are 2 piece and have a metal sleeve in them. The Poly's shoudl be stiffer and reuse the metal sleeve, no?
Are you referring to drilling out the metal sleece for the bigger Koni piston?
Old Jul 19, 2002 | 06:48 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Polyurethane ITR shock bushings (Asahi)
You can reuse the metal sleeve (edit): with the polys if this is a stock width rod, but it is quite a bit squishier. The sleeve butts up against 2 metal plates on the stock bushings, because the stockers are pretty much entirely metal on one side, and have a hard rubber coating on the other. They're actually quite good, and I wouldn't replace them unless it's with spherical bearings. The poly ones are softer, and they have a bigger taper to them, so there isn't as much material there.
The Konis come with a sleeve which has a bigger hole, and this is why I had to drill out the stock bushings, so that the hole from the sleeve would match up w/ the one from in the bushings. I had a machine shop do this though, to make sure it was exact.
Warren
[Modified by Warren, 10:57 AM 7/19/2002]
Old Jul 19, 2002 | 07:08 AM
Asahi's Avatar
Warren
YOu know what I just remembered. YOu are talking about ITR cpas and bushings and you are rights. ALL other inbtegras have different bushings and are not like that. THe are just rubber with the metal sleeve through the center. I unwittingly put GSR caps and bushings on my TEIN HA's and they are compleyely different than the ITR caps.
trey
Old Jul 19, 2002 | 08:35 AM
617arg's Avatar
Warren
so from the complete "hyper-flex" kit, which bushings are harder than the stock ones?
HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: front and rear control arm bushings, front and rear shock bushings, front end links, steering rack bushings (power steering only), transmission shifter stabilizer bushings (manual transmission only), ball joint and tie rod end boots.
i just got my coilovers and would like to change the bushings while i'm installing them.
thanks for your help
argiris
Old Jul 19, 2002 | 09:46 AM
norice's Avatar
Default Re: Polyurethane ITR shock bushings (ITR#132)
If you are talking about the top hat bushings, then I don't think you are right. Fronts are also different.
cf.
Old Jul 19, 2002 | 09:49 AM
Asahi's Avatar
Default Re: Polyurethane ITR shock bushings (norice)
I agree, caps are different for front and rear but shock bodies are different for rear only.
Old Jul 19, 2002 | 09:53 AM
norice's Avatar
By shock bodies, I presume you mean the rear LCA mounting points of the shocks? Obviously, front and rear ITR shocks are different internally from standard Integra shocks.
Old Jul 19, 2002 | 09:55 AM
Asahi's Avatar
exactly. Just the outter lower parts by body I meant outter casing.
Old Jul 19, 2002 | 02:49 PM
Vitt1's Avatar
I went to a local dealer to try to sort out the differences, and the guy confused me even more. He pulled the 94 GSR shock picture and the one for 97 ITR. Then he told me that the GSR doesn't have those bushings at the shock hat. He said all the 94 GSR had was the bumpstop (he just pointed to it).
That doesn't make sense, but I wasn't going to waste my time since he didn't seem to know what he was talking about. I just learned this, but according to the sales guy, if you pull up the pic and click on it, it will highlight if that particular model and year uses it. When he clicked on the 94 GSR's it didn't highlight.
The acuraautomotiveparts.net site doesn't list the Acura part #, I guess those are their own internal ID numbers. Anyway, they are the same for all the ITR and GSR bushings front and rear. In any case, they are pretty pricey. $9 each x8 = 72
I got the part # for one of the ITR's. Can anyone confirm the part number for the GSR?
Old Jul 19, 2002 | 03:00 PM
norice's Avatar
No they are not. If you look closely at the first diagram, the standard Integra part is #7 and the other (Type-R) part is #8. The Carland number for #8 35682.
If you look at the rears, the standard Integra part is #17 and the other (Type-R) part #2, with an identical Carland number to the front Type-R parts of 35682.
In sum: the Type-R has different hat bushings than the standard Integra and uses the same bushings front and rear. A complete set of 8 is required (2 per corner).
Thanks to Jeff652 for help clearing this up.
[Modified by norice, 4:03 PM 7/19/2002]
Old Jul 19, 2002 | 03:19 PM
Vitt1's Avatar
Yeah, I see. I wasn't reading the diagram correctly. Thanks for clearing that up.
What confused me is that the guy at the dealer didn't mention that the GSR uses #7 and 17 instead of the the ITR's # 8 and 2.
Old Jul 19, 2002 | 03:22 PM
norice's Avatar
Well, the diagram is not all that clear. Most dealers tend to know diddly about everything.
Old Jul 19, 2002 | 04:10 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Polyurethane ITR shock bushings (argiris)
All except for the shock bushings are harder. Just be careful though if you're using them on the front lower control arms. They tend to bind/crack under racing conditions. To minimize the chance of this, keep them well lubed, and do not torque the bolts until the control arm is at the right angle (as if it was sitting on the ground).
Warren
miketegra
Jun 26, 2004 08:44 PM
Shark Tank
Feb 16, 2003 05:06 PM
keys
May 17, 2002 06:07 AM
Disco Monkey
Oct 16, 2001 07:05 PM
