OBD1 GSR motor into OBD2 98 EK
Old Jul 1, 2008 | 12:00 PM
ShagPower's Avatar
Default OBD1 GSR motor into OBD2 98 EK
a buddy of mine is about to install an OBD1 JDM GSR motor into his 1998 civic DX. We're stumped over the wiring issue. We have the stock civic wiring harness, we also have the motor harness from the GSR motor.
What would be the easiest route to wire the motor? I would think by using the stock harness then converting over a few things like the distributor and injectors (anything else???). The ecu being used is also OBD1, he does have the OBD2-OBD1 jumper harness though so that's not an issue.
What would be a good way to go about this?
Old Jul 1, 2008 | 12:13 PM
hotrod99's Avatar
Default Re: OBD1 GSR motor into OBD2 98 EK (ShagPower)
https://honda-tech.com/zerothread?id=502538
Old Jul 1, 2008 | 01:00 PM
ShagPower's Avatar
Default Re: OBD1 GSR motor into OBD2 98 EK (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=502538</TD></TR></TABLE>
other way around
Old Jul 1, 2008 | 01:01 PM
dafuzzbudd's Avatar
are you running the motor obd1 or obd2?
obd1: you need to rewire/elongate plugs to match but the harness should be fine. you'll also need a obd2&gt;1 ecu harness
obd2: buy obd2 alt/dist/inj. might have to extend some sensors. everything should plug up though including ecu.
this basically seems to be the way it works
Old Jul 1, 2008 | 01:30 PM
ShagPower's Avatar
Default Re: OBD1 GSR motor into OBD2 98 EK (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">are you running the motor obd1 or obd2?
this basically seems to be the way it works</TD></TR></TABLE>
running an OBD1 ecu (we have the conversion harness for the ecu OBD2-OBD1). So it would be best to use the obd2 stock harness and rewire it to the obd1 motor? we can use the obd1 plugs from the motor. alt/dist and injectors and thats it?
TravisBiggie
May 24, 2012 07:13 AM
Ricky616
Jul 2, 2009 01:44 PM
B18C1 '96 Coupe
May 21, 2003 02:25 PM
