brake rotor question
I don't know why you would want Civic rotors on an S2K but I believe up to 2005 they were 4 lug and after they are 5 lug. So if the rotors are from an 06' they will fit the lug nut pattern, but I am have never owned a civic so I could be wrong. Again why would you want civic rotors on an S2k are they aftermarket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joro Corona »</TD></TR><TR><TD CLASS="quote">Pritty sure Joey is full of ****.</TD></TR></TABLE>
pretty sure your mom is too
I was looking for some cross drilled brembo rotors and they don't have it for the s2000...they only had civic rotors. also, they're cheaper..if they fit what does it matter which car they are for?
<FONT SIZE="5">No they do not fit</FONT>
Are you looking at spending any time on the track with your S2000?
Non-slotted and drilled rotors are really your best bet. Slotted and/or drilled rotors cause shorter pad life, higher noise, and are more prone to cracking. They also offer you less surface area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthralled »</TD></TR><TR><TD CLASS="quote">I was looking for some cross drilled brembo rotors and they don't have it for the s2000...they only had civic rotors. also, they're cheaper..if they fit what does it matter which car they are for? </TD></TR></TABLE>
why cross drilled rotors? looks or actual braking performance?
anyways i found you some slotted ones here:
http://gruppe-s.com/S2000/s2kbrk.htm
now gtfo
now gtfo
I have done a bit of research on other parts, but i don't know anyone with a civic so i can't just go look at it. I know some of you have civics as beaters, so i was wondering if anyone knew if they would fit.
after owning cross drilled and slotted rotors on my old integra i am never getting cross drilled again my bitches cracked. but i did get good life out of them and beat them on a dialy basis.
for my s im sticking with the stock rotors. upgrading ur pads will give u the best bag for ur buck.
but like u said its only for looks so just go to ebay and buys cross drilled and slotted ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthralled »</TD></TR><TR><TD CLASS="quote">will the civic rotors fit the s2000?</TD></TR></TABLE>
WOW best thread right here
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthralled »</TD></TR><TR><TD CLASS="quote">so...I guess the answer is no.
thanks guys.</TD></TR></TABLE>
YA THINK!?!?!?!
trade in ur S and buy a civic, then u can buy your super sweet cross drilled rotors... seriously what are you thinking???
YA THINK!?!?!?!
cross drilled does NOTHING! plus, if you're going to cheap out price wise on something that matters (brakes, suspension, tires, etc), you might as well drive your car off a cliff.
if they fit the car, dont you think the company would have the brilliance to say that the same rotors fit the s2000? i mean for ***** sake
...Just go back to reading your import tuner, and never come back this this forum...for your own good.
Tips:
1. Research and common sense are your friend.
2. Cross drilled rotors are POS, and they will crack under stress.
3. Learn to stick to QUALITY parts, over what you THINK looks good.
4. If money is tight...you really shouldn't be owning/driving an S2000 to begin with...regardless of the year or condition. Don't be a cheapass.
Tips:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. »</TD></TR><TR><TD CLASS="quote">
if they fit the car, dont you think the company would have the brilliance to say that the same rotors fit the s2000? i mean for ***** sake</TD></TR></TABLE>
no because that would make way too much sense...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis »</TD></TR><TR><TD CLASS="quote">
Tips:
X2
Tips:
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthralled »</TD></TR><TR><TD CLASS="quote">No, I do not have time to track my car...I work 80+ hours a week. It's mostly for looks.</TD></TR></TABLE>
Real. True. Tuning.
Real. True. Tuning.
