Pulling Battery Cable while car is running.
Old Jul 1, 2008 | 11:31 AM
rSol93's Avatar
Default Pulling Battery Cable while car is running.
Will this cause a problem? Because now my car won't start. It will turn over but won't start. I smell gas.
Plugs, Cap, Rotor, Main Relay was all changed not too long ago.
Its getting gas, compression, but no spark.
Im guessing something is messed up in the ignition system.
Modified by rSol93 at 12:39 PM 7/1/2008
Old Jul 1, 2008 | 12:01 PM
4drkidd's Avatar
Bump, someone help him out, I'm having the same problem..
Old Jul 1, 2008 | 12:10 PM
girlsaremean's Avatar
Default Re: (4drkidd)
No, it won't cause a problem, although if you disconnect the positive cable and leave the ground cable connected and drove around, it is possible that the power cable could hit a ground and arc. but lets say you started your car then disconnected both cables from the battery, wouldn't be a problem.
Old Jul 1, 2008 | 12:32 PM
dognutz's Avatar
Default Re: (girlsaremean)
Sounds like something in the dizzy (ignitor or coil). Did you check the voltage of the battery?
Old Jul 1, 2008 | 12:42 PM
marcs1337's Avatar
it usually doesnt cause a problem, but it can...if there was to be some kind of voltage spike and the battery isnt in there...it could be bad
Old Jul 1, 2008 | 12:44 PM
EL Vap133's Avatar
Default Re: Pulling Battery Cable while car is running. (rSol93)
Is the rotor on? Sometimes it can fall off if it isn't tightened.
Old Jul 1, 2008 | 12:53 PM
rSol93's Avatar
pulled the cap off the rotor and couldnt get the rotor off, then i notice there isnt a screw in it, so i pry it off then the screw falls on the ground, put that back on and try again. It starts if I give it gas while its trying to crank.
Old Jul 1, 2008 | 03:12 PM
fastrc2's Avatar
if it starts only when you give it gas, then the IAC is not operating.
Old Jul 1, 2008 | 04:36 PM
rSol93's Avatar
There is also a strange knock like something is hitting something when I crank it.
Ill get a video for you guys soon.
Old Jul 1, 2008 | 05:31 PM
rSol93's Avatar
http://www.youtube.com/watch?v=o7AoYHoXIAM
Old Jul 1, 2008 | 06:13 PM
sorullo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by girlsaremean &raquo;</TD></TR><TR><TD CLASS="quote">No, it won't cause a problem, although if you disconnect the positive cable and leave the ground cable connected and drove around, it is possible that the power cable could hit a ground and arc. but lets say you started your car then disconnected both cables from the battery, wouldn't be a problem.</TD></TR></TABLE>
[B]well if you disconnect the two cables the car will run only with the alternator..that's what the alternator is for... there is no problem with that.. but if you disconnected and the car turn off ,then is the alternator.. need to replace it..
get another battery.. turn the car on.. if it goes on disconnect the positive cable, and if the car still on then is was your old battery.. if it goes off then is the alternator...
but also check all your fuses and relays on the hood relays comparment..
it could be the fuel pump relay also.cuz when the realy is bad it shuts off the fuel pump...
[B]
Old Jul 1, 2008 | 06:49 PM
4drkidd's Avatar
Wow, after watching that video, I felt as if I was in my own car..
Good luck bro.
Old Jul 2, 2008 | 12:52 PM
4drkidd's Avatar
Bump for some help...
Old Jul 5, 2008 | 12:22 PM
rSol93's Avatar
My issue was the ICM in the distributor, took it out and went to autozone and they tested it and it proved to be bad. Swapped it out and running fine now.
Tallon22
Honda Civic (2001 - 2005)
Jun 22, 2014 11:17 AM
tsjeff
Feb 28, 2010 10:43 PM
I Like Hondas
21
Sep 29, 2006 02:56 PM
heyitzspikey
Oct 10, 2005 06:53 PM
gumbybum
Feb 8, 2003 11:25 PM
