New alternator and car still doesnt stay charged!
Old Jul 1, 2008 | 10:49 AM
BoltonGSR's Avatar
Default New alternator and car still doesnt stay charged!
My car after a few days after a battery charge would eventually not start..
I diagnosed as much as i could and swapped the alternator.. same problem!
My only thought is i drove around on the old alternator (the one i suspect was bad) for a day before i put the new alternator in and didnt charge the battery back up.. Now 4 days later the car wont start again.. But i have power everywhere else??
Could it be because i operated my battery on the bad alternator for that one day?
Old Jul 1, 2008 | 10:51 AM
all-mtr-teg's Avatar
Default Re: New alternator and car still doesnt stay charged! (BoltonGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">My car after a few days after a battery charge would eventually not start..
My only thought is i drove around on the old alternator (the one i suspect was bad) for a day and didnt charge the battery back up.. Now 4 days later the car wont start again.. But i have power everywhere else??
Could it be because i operated my battery on the bad alternator for that one day?</TD></TR></TABLE>
That's a possibility. Get your battery tested at autozone or kragen for free.
BoltonGSR's Avatar
Default Re: New alternator and car still doesnt stay charged! (all-mtr-teg)
Thanx for the quick reply.. it is currently at autozone being charged...
Old Jul 1, 2008 | 12:06 PM
CJR's Avatar
CJR
I too have the same problem.. Duno what the hell it could be. I have takin it to electricians and they couldnt find anything
Old Jul 1, 2008 | 12:14 PM
Nataku's Avatar
Default Re: (CJR)
Check to make sure you do not have some kind of fuse for the alternator that is blown.
Old Jul 1, 2008 | 02:40 PM
BoltonGSR's Avatar
Default Re: (Nataku)
I looked in my helm and checked the fuse and it was ok..
Wtf else could it be?
Help...
Modified by BoltonGSR at 5:47 PM 7/1/2008
Old Jul 2, 2008 | 05:56 AM
BoltonGSR's Avatar
Default Re: (BoltonGSR)
ttt
Old Jul 2, 2008 | 07:52 AM
CJR's Avatar
CJR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">Check to make sure you do not have some kind of fuse for the alternator that is blown.</TD></TR></TABLE>
Uhhh LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CJR &raquo;</TD></TR><TR><TD CLASS="quote">I too have the same problem.. Duno what the hell it could be. I have takin it to electricians and they couldnt find anything </TD></TR></TABLE>
Old Jul 2, 2008 | 08:00 AM
Do you have any aftermarket accesories, stereo system, t.v., etc that could be drawing power even after the car is off? You may have a short or bad relay.
My alarm has an option that closes my sunroof automatically once my alarm is set. A relay is supposed to shut off the sunroom motor after the sunroof closed. This relay went bad and caused the sunroof motor to stay running continuously once I set my alarm, until my battery died.
Old Jul 2, 2008 | 09:09 AM
lsvtecboi'95's Avatar
i have a similar probably .. i put a battery in my car, new alternator, new starter, and my car still seems not to start on occasions .. seems like it only starts when it wants to.
Old Jul 7, 2008 | 02:19 PM
BoltonGSR's Avatar
Default Re: (lsvtecboi'95)
Ok i the car still does this ****.. It dies so i jumped it with some wires and it started right up..
I took the battery to have it tested and it wasnt even low..
WTF??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any aftermarket accesories, stereo system, t.v., etc that could be drawing power even after the car is off? You may have a short or bad relay.
My alarm has an option that closes my sunroof automatically once my alarm is set. A relay is supposed to shut off the sunroom motor after the sunroof closed. This relay went bad and caused the sunroof motor to stay running continuously once I set my alarm, until my battery died.</TD></TR></TABLE>Yes i have an alarm and aftermarket radio (sony xplod)
Which relays should i check?
Could this be a starter problem cause it sure as hell aint my battery or alternator like stupid *** autozone said!!
Help...
Old Jul 7, 2008 | 02:24 PM
How did they test your alternator at AZ, on the benchtop unit or while it was in your car? It wouldn't be that starter otherwise the car wouldn't have started even after you used jumpers.
Old Jul 7, 2008 | 02:56 PM
BoltonGSR's Avatar
I replaced the alternator with a reman.. What is AZ?
They only tested the alternator while in the car and only at the battery..
Old Jul 7, 2008 | 03:02 PM
AZ = autozone. It's good they tested it while still in the car. If they did the test right, that is a better representation of the load actually being pulled by your car, instead of the load from the benchtop tester.
Old Jul 7, 2008 | 03:14 PM
BoltonGSR's Avatar
Default Re: (all-mtr-teg)
They tested them and said they were both good...
What the hell is my problem then... if its not the starter, alternator or battery...
Old Jul 7, 2008 | 05:31 PM
Rediness_code's Avatar
Perform and amperage draw test.
Old Jul 7, 2008 | 06:38 PM
BoltonGSR's Avatar
Which relays should i check? And how do i check to see if one is bad???
My car is starting fine now... what the hell. Its like it only dies once out of every 20 times then it gets jumped and is fine for another 20...
Bump, suggestions.. I already wasted 130 dollars parts changing because i trusted some 40 year old parts changing autozone guy that said it was an alternator
Old Jul 7, 2008 | 06:54 PM
1998_4dr_gsr's Avatar
My mom's TL had the same problem. It's not the batt or alternator. It's the starter. Try to crank it and it doesnt even crank? If it doesnt even crank...i'm pretty sure your starter is going bad.
Old Jul 7, 2008 | 06:58 PM
BoltonGSR's Avatar
Default Re: (1998_4dr_gsr)
I was considering that thought too.. Is there any way to test a starter?
Old Jul 7, 2008 | 07:26 PM
It starts sometimes right? ............... There you go.
Old Jul 7, 2008 | 07:28 PM
When it doesn't start.. I remember I would turn off ignition and retry and after 5-10 times it would crank at least once. If you have that same symptom, I'm pretty sure it's your starter. Can anyone confirm??
Old Jul 7, 2008 | 08:27 PM
ruffrhyder's Avatar
It may be something as simple as a loose terminal. Check to make sure all the connections on the starter are clean and tight. The connection on the starter solenoid maybe corroded or loose. Get yourself a manual and start elliminating probable causes.
obuhmyuh
May 28, 2008 03:27 PM
97_hatch
May 21, 2008 02:38 PM
calean
Nov 18, 2004 03:55 PM
ownedbyvtec
Aug 24, 2003 01:18 AM
Fatty_1775
Oct 23, 2002 02:33 AM
