PIC coilovers ????
Old Jul 1, 2008 | 10:45 AM
lilbill_ed8's Avatar
Default PIC coilovers ????
hi .. i am going to be picking up a dc integra soon and was wondering if my pic coilovers off of my crx would work on a newer honda. the only reason i want to do this is because the teg is sitting on ebay coilovers right now
sorry for asking because i know i have seen this question before but i just cant find any of those other posts
thanks for the help in advance
Old Jul 1, 2008 | 11:10 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: PIC coilovers ???? (lilbill_ed8)
They'll fit, but the dampening rates will be incorrect. If you want to use them, I would keep them as a temp replacement until you find some made for a dc.
Old Jul 1, 2008 | 01:43 PM
be18see1's Avatar
Default Re: PIC coilovers ???? (CARMA_626)
actually, you may have some problems witht them fitting in the front forks of the dc. you may need to use the ef forks.
Old Jul 1, 2008 | 02:04 PM
TOO MUCH TORQUE's Avatar
arent the crx and gsr/ls lcas designed differently?
Old Jul 1, 2008 | 02:32 PM
CARMA_626's Avatar
Default Re: (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">arent the crx and gsr/ls lcas designed differently? </TD></TR></TABLE>
Good point - I believe the early year CRX's use LCA's that accept the eye style shock, just like the ITR. However newer EF's use the regular LCA's found on DC/EG's.
Old Jul 1, 2008 | 02:52 PM
mike-y's Avatar
Default Re: (CARMA_626)
only the 88 civic/crx rear LCA's are different. They are box type, like the ITR, but the "box" area is a bit narrower than the one on the ITR (or jdm EG/DC).
and you'll need to use the crx front forks on the DC to use the CRX shocks. if you have an 89+ CRX, then the rear shocks/springs will bolt right up.
Old Jul 2, 2008 | 12:27 AM
cool thanks for all your help guys i will run these till i can buy ones made for the car. the part i was worried about was how the strut assembly was so much shorter then that of a dc eg chassis and my freinds said the car would be on the ground. i didnt even think about the fork or lca.. but yeah expect to see a build post from me in the next couple weeks.. h2b dc anyone
Rob.
Suspension & Brakes
119
Aug 31, 2009 06:56 PM
biggjerryc
Jun 17, 2008 07:14 PM
tegman23
Feb 24, 2008 02:38 PM
mormonboy
Suspension & Brakes
Jun 16, 2007 08:40 PM
crxmadman
Jul 23, 2005 03:21 PM
