instrument cluster
Old Jul 1, 2008 | 10:30 AM
ridgewayballa's Avatar
Default instrument cluster
My dash and speedometer lights aren't working and the fuse isn't blown. Someone told me i needed another instrument cluster. What do u think i should do?
Old Jul 1, 2008 | 10:41 AM
TheMuffnMan's Avatar
* B A N N E D *
Let me guess - your corner parking lights don't come on either?
It's the small lights fuse under the hood. Look again.
*edit*
That or the dimmer switch isn't working.
Old Jul 1, 2008 | 10:44 AM
Default Re: (TheMuffnMan)
the parking lights work
Old Jul 1, 2008 | 10:56 AM
* B A N N E D *
Dimmer switch is the problem them. That rectangular thing with the screw adjustment for the brightness.
Old Jul 1, 2008 | 10:58 AM
how do i fix it?
Old Jul 1, 2008 | 11:15 AM
* B A N N E D *
Pop it out and replace it with a working one?
Old Jul 1, 2008 | 11:57 AM
so i don't need to replace the cluster?
Old Jul 1, 2008 | 12:19 PM
* B A N N E D *
No, just the dimmer switch.
Old Jul 1, 2008 | 01:03 PM
i have a 2001 honda accord and the dimmer switch is built into the instrument cluster so wouldn't i have to replace the cluster?
Old Jul 1, 2008 | 02:46 PM
TheMuffinMan's Avatar
He knows where you live!
Well way to post that info earlier :/
I'm not sure how those years work
Old Jul 2, 2008 | 10:16 AM
tburtnett's Avatar
Default Re: instrument cluster (ridgewayballa)
I have a 99 accord coupe. I pulled out the cluster and swapped out the bulbs. You probably need to do the same.
Old Jul 2, 2008 | 10:55 AM
Sketch o5's Avatar
if it is the dimmer, then you need to take the cluster completely apart and see if the switch is soldered to the circuit board on the back. if it is, then youll need a new cluster, if not, then you can replace it.
i just had mine apart today, its real easy to do. to take the individual gauges out of the cluster tho, there are these tabs on the back, bend them straight, then push on them, gently, till the corresponding gauge is loose and you can take it out. the circuit board wont come off the back with the gauges mounted to it.
zpayne21
Jan 5, 2015 07:07 PM
millertime1388
12
Sep 8, 2010 07:59 PM
sins
Jan 13, 2010 03:22 PM
b18c1del
Aug 22, 2009 01:25 PM
dravesef
Jun 19, 2008 03:46 PM
