b16 header?
just purchased a dc 4-2-1 header for my b16. what is the best way to install it. should i go from the top or the bottom. and will i need to take out my radiator for more room. i had to pound out the crossmember a lil to fit my stock ex. manifold. but will prob have to pound it more. just want some advise before i start.
Drop the front crossmember & install from the bottom.
Remove the four main crossmemeber bolts, pull it down a bit & loosen the radius rod bolts. Install the header, tighten radius rod bolts, reinstall main front crossmember bolts.
Eric
Eric
subtleluck
May 31, 2003 01:20 PM
