front end question?
Old Jun 30, 2008 | 11:03 PM
DeaDPooL's Avatar
Default front end question?
I just got into an accident last tuesday.. I got all my cosmetic taken care of, but im stuck on why my drivers side tire is sitting 2-4 inches back.. I replaced the axle and lower control arm.. any ideas?? heres the pic.
Old Jun 30, 2008 | 11:37 PM
4drkidd's Avatar
Is there any frame damage?
Did you check around the axles to see if anything looked out of place or bent?
If it was pushed back a few inches then something isn't aligned right..
Check again and look into the littlest detail.
Old Jul 1, 2008 | 04:29 AM
alphalanos's Avatar
Default Re: (4drkidd)
jack it up and take a bunch of pics. somethings bent/broken.
Old Jul 1, 2008 | 06:23 AM
DeaDPooL's Avatar
Default Re: (alphalanos)
no frame damage at all. nothing looks bent or broken.. but i will take pics.
Old Jul 1, 2008 | 09:45 AM
kr's Avatar
kr
Default Re: (DeaDPooL)
if the wheel is sitting back to far then something is bent.
Old Jul 11, 2008 | 02:55 PM
DeaDPooL's Avatar
Default Re: (kr)
Old Jul 11, 2008 | 04:06 PM
alphalanos's Avatar
Default Re: front end question? (DeaDPooL)
Did you get the whole control arm or just the back portion? It looks like the front part, the straight peice that connects to the hub might be bent. Because to me it looks like your shock is tilted forward which would coincide with a bent arm. also you tie rod needs to be changed.
Old Jul 11, 2008 | 04:08 PM
DeaDPooL's Avatar
Default Re: front end question? (alphalanos)
i haven't changed anything as of yet. I was looking at some things today and took the pics. when i took the tie rod off, I could not get it aligned back up straight with out putting like it was.
Old Jul 12, 2008 | 02:05 PM
DeaDPooL's Avatar
Thank you alphalanos. A new lower control arm fixed it. time for an alignment.
92integraVTECgsr
Dec 10, 2012 03:27 PM
Newton
38
Apr 7, 2010 10:58 PM
RomesEM1
Suspension & Brakes
Aug 24, 2009 02:02 PM
patastinky
Mar 24, 2003 02:21 PM
dan89crxsi
Jan 6, 2003 11:03 PM
