FL-built/boosted EG hatch FT
92 CX hatch lightest year and body style
motor is a built poormans type-r with B16 tranny
Turbo kit-
SpoolinPerformance Prototype1 manifold w/ downpipe
T3/T4 turbo (turbonetics I believe, w/v band on exhaust side)
3 Inch V-band downpipe
Turbonetics deltagate wastegate
return and feed lines
Mitsu 440 injectors
Honda resistor box
Greddy VSPL FMIC w/all piping and couplers
DNA manual boost controller
limited edition greddy boost gauge (silver/red backlighting) peak/hold/warning
Im sure theres a couple more little things im forgetting
motor-
00 GSR DOT Block
00 GSR Crank
New OEM Honda ITR Oil & Water pumps
New OEM Honda GSR Timing Belt
Clevite STD Rod Bearings
Eagle H-Beam rods
CP 9:1 81mm bore pistons
Fresh Hone
ARP headstuds
95 PR3 Head
New OEM Honda Valve Seals and Head Gasket
Skunk 2 Tuner Ti Valvesprings
Skunk2 Tuner Ti Retainers
Skunk2 Intake Manifold
Skunk2 Stage 2 Cams
Hondata Phenolic Intake Manifold Gasket
OEM S2K TB
OEM 00 Si Distributor
Has an ACT HD/SS clutch and Hydro Intermediate shaft on it as well
Build has less than 2500 miles on it gets 182 - 185 - 185 - 180 on compression test with 2-3 % leakdown
Car needs to be tuned im trying to set up an appointment currently hopefully this weekend, car needs paint and interior to be 100% its whit primer right now
im in riverview/brandon FL best way to contact me is cell 813-892-0334 Cody
basically looking for something a little more family friendly need something with A/C to carry around the one year old in...wish I could keep it put some bigger injectors in and make some decent power LMK what ya got
Turbo kit-
Mitsu 440 injectors
Honda resistor box
motor-
00 GSR DOT Block
00 GSR Crank
Eagle H-Beam rods
Fresh Hone
ARP headstuds
95 PR3 Head
Skunk2 Stage 2 Cams
OEM S2K TB
djtrini
Aug 7, 2007 05:35 PM
