Dropped a valve
Old Jun 30, 2008 | 05:33 PM
Integrabeast's Avatar
Default Dropped a valve
Is the motor salavagable if i dropped a valve. I think its stuck in the cylinder. I tried cranking by hand and piston wont come up. please help.
Old Jun 30, 2008 | 08:11 PM
downest's Avatar
Default Re: Dropped a valve (Integrabeast)
It's probably done, you should pull the head and have a look. It may not be turning over because of the crank. A few months ago a customer of mine shifted his S2000 into 2nd at 120MPH... cracked a roller bearing in the head and dropped two valves in #4, the valves were in the exhaust (mostly) and the crank actually bent so you couldn't rotate the motor very far by hand.
Old Jul 1, 2008 | 10:51 AM
vtecb18c's Avatar
Default Re: Dropped a valve (downest)
yea sounds like its time for a rebuild
BIGef
Jul 6, 2012 10:17 PM
D21X
Aug 8, 2010 06:28 AM
suprmods
Dec 19, 2005 03:34 PM
rob2_0_0_5
Oct 1, 2005 02:28 PM
RTW DC2R
Dec 22, 2004 12:31 PM
