tranny filler bolt
Old Jun 30, 2008 | 04:38 PM
trevorjohn88ef's Avatar
Default tranny filler bolt
well went to go change my tranny fluid in my crx with a b16 swap and the filler plug bolt is right up against the inner front lca mounting point. i cant even get a socket up against it, any idea on how i can get to it without taking it to a shop or lowering my tranny?
Old Jun 30, 2008 | 05:00 PM
JOE BD-0's Avatar
Default Re: tranny filler bolt (trevorjohn88ef)
Will an open end wrench fit? Don't drain the trans until you get the filler bolt off and your sure you can fill it. good luck
Old Jun 30, 2008 | 05:31 PM
Default Re: tranny filler bolt (JOE BD-0)
yes but they say the bolt strips really easily so i dont want to chance it, but yea i didnt drain it yet
Old Jun 30, 2008 | 05:51 PM
Crx Jimmy's Avatar
use an open end wrench, the ratcheting 6pt ones work real good
Old Jun 30, 2008 | 11:30 PM
Default Re: tranny filler bolt (Crx Jimmy)
never thought about that, thanks
Old Jul 1, 2008 | 04:00 AM
beana's Avatar
i drain mine and fill it through the reverse sensor sure it takes a while but it works
as for how much you'll need to pull the fill plug best way to do it in my book you put the front on jackstands pull the fill plug forst then the drain plug ,drop the car back on the ground pull the reverse sensor then fill it through there then just reverse the operation
Old Jul 1, 2008 | 10:24 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: tranny filler bolt (beana)
the reverse sensor is a whole lot of drama to pull out and put back in, compared with just making sure your car is level on the jack stands and filling as originally intended. I have tried both ways, and in my opinion, it is much easier to just fill as it was intended.
oh yeah, and the filler bolt is a 17mm i believe. so get the 17mm 6 point box end and you will be in business.
Old Jul 1, 2008 | 03:59 PM
Default Re: tranny filler bolt (sanimalp)
well i figuered it out they didnt make a 6 point ratcheting wrench so i just used a normal 6 point wrench, filled it up with 2 quarts of redline mt 90 but it still grinds maybe even a little more, i asked and some people said it'll take a day or 2 to feel a differnce, that true?
Old Jul 1, 2008 | 10:17 PM
sanimalp's Avatar
$cat /dev/urandom
yeah, it may take a little while.. but if it is still grinding, the fluid isnt really much of a fix anyway.
Old Jul 2, 2008 | 03:25 AM
schueytenten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">compared with just making sure your car is level on the jack stands and filling as originally intended.
How do you make sure the car is level? I just throw a level on the sunroof?
Let me know the real way.
Old Jul 2, 2008 | 05:32 AM
gursh d's Avatar
If the 6 point wrench still isn't working, you can remove your VSS temporarily and fil your fluid from there.
Old Jul 2, 2008 | 10:59 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: tranny filler bolt (gursh d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schueytenten &raquo;</TD></TR><TR><TD CLASS="quote">
Let me know the real way.</TD></TR></TABLE>
Well, there isn't really any science to it. I just jack up the front and rear, and make sure the rear is eyeball'd level or a tad bit higher. if the car is jacked about an inch or 2 higher in the back than the front, you won't spill any oil at all filling through the filler bolt hole.
I used to just jack up the front end and change it that way, but you can potentially loose a lot of oil if don't get the filler bolt in quick enough. That happened to me several times and I decided there had to be a better way.
Old Jul 2, 2008 | 11:35 AM
well what i did was jack the front end up, took the filler and drain plug out, lowered the car down to stock to drain the rest of the remaining trans fluid, plugged the drain hole, lifted the car up enough in the front to get my hand in there to fill the fluids, matched the rear of the car with the front to get a level car, plugged the filler hole and on my way i went.
Damon Reeves
Apr 15, 2007 09:11 AM
midnitesol
Jan 20, 2007 05:44 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
lke2drvgsr
Apr 6, 2004 02:49 PM
Batoutahell
Oct 17, 2002 06:36 PM
