Oil in Spark Plug Tunnels
Well, in my stock B18B1, there is oil slowly leaking in the spark plug tunnels (i don't know the actual name) and causing the car to have a rough start, how would i drain the tunnels and then prevent the oil from doing the same thing again?
Any help is appreciated
Get a new valve cover gasket and that will come with the seals that go between your valve cover and the spark holes in the head where you install your spark plugs. As for cleaning it out I'd say try an blow it out with compressed air.Make sure u have the plugs in so u don't blow and dirt or other materials into the cylinder. Or you could try and wrap a rag around a screwdriver and soak up the oil.
Come to think of it I think when I had that problem before I did just let it drain into the cylinder and burn the oil up. I don't remember if i tried soaking it up with a rag or not just seemed like a good idea when I read your post last night...
No no no I had this problem hhappen to me. New valve cover gasket and rings. Wat he means is let the oil from inside the spark plug "tunnels" go into the engine, after it is all drained clean the sparks again put em on and let the engine on for a bit so the oil inside the engine (that drained from tunnels) burns. All youll see is smike comin out from the exhaust for abit. But not a big issue...common
