compression tested today?
Old Jul 18, 2002 | 06:37 PM
APEXI Si's Avatar
Default compression tested today?
I did my compression today on my b16a. Every thing is stock. I got 215 in every cylinder. Is that good, and what would my ratio be. thanks guys.
Old Jul 18, 2002 | 06:59 PM
-=TWITCH=-'s Avatar
Default Re: compression tested today? (crx616)
as long as they are close you ar ok
Old Jul 18, 2002 | 07:08 PM
APEXI Si's Avatar
Default Re: compression tested today? (-=TWITCH=-)
I know but is that high or low compared to everyone else
Old Jul 18, 2002 | 08:03 PM
Griffins_Importuning's Avatar
i got anywhere from 170-185...
Old Jul 18, 2002 | 08:07 PM
APEXI Si's Avatar
Thanks, has anyone else compression tested their b16.
Old Jul 18, 2002 | 08:11 PM
i think the manual says 175-185...dont quote me on that. give or take 15 per cylinder. i would not worry about it. ****. u have high compression. worry if it is low. but thats just my 2 cents...
Old Jul 18, 2002 | 10:37 PM
RexB16's Avatar
if everything is stock then ur comp ratio is 10.2:1
Old Jul 19, 2002 | 12:07 PM
APEXI Si's Avatar
Default Re: compression tested today? (RexB16)
If stock is between 175-185 then why is mine so high. I know that it is good to have high compression but what would have caused mine to be so high. dose it matter if it is jdm or not. mine is.
Old Jul 19, 2002 | 12:54 PM
Urban Business
Guest
Posts: n/a
what is the formula to convert psi to ratios?
Old Jul 19, 2002 | 02:33 PM
RexB16's Avatar
Default Re: compression tested today? (TorteX)
i dont think there is one... i thought you calulated ratios based on bore/stroke, piston height and combustion chamber volume.
Old Jul 19, 2002 | 02:36 PM
BoostedED9's Avatar
i did one on my friends old b16 when he had a bad headgasket and it was at around 213 and one was at like 156 then wwent back up..... and my sohc vtec is at around 195 so 215 sounds fine..
Old Jul 19, 2002 | 02:50 PM
CRX7's Avatar
Default Re: compression tested today? (ED9Hybrid)
I got 210 on three of mine and 170 on one. So 215 across the board is really good
Old Jul 19, 2002 | 02:53 PM
CRX7's Avatar
Default Re: compression tested today? (CRX7)
anybody know how to do a leakdown test and where I can get a leakdown tester at. I've got a compressor, all I really need is an attachment to go from my compressor hose to the spark plug hole. Any ideas?
Will I need to take off my intake manifold, exhaust manifold, and oil pan to hear the air coming out.
Also, my compressor maxes out at about 125 should I just take this to a shop.
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
wm5holla
Jan 7, 2003 07:06 AM
90da4dr
Nov 3, 2002 09:10 AM
stupidfast
Oct 20, 2002 03:50 PM
