distributor fork
Old Jul 18, 2002 | 06:20 PM
LB CRX's Avatar
Default distributor fork
i dont know what its exactly called, but its the fork outside if the distributer that connects to the cam. is it supposed to be able to rotate 360 degrees? mine stops like at 100 degrees. could something be messed up? TIA
Old Jul 18, 2002 | 06:55 PM
minime's Avatar
Default Re: distributor fork (LB CRX)
yes it should rotate 360. you need a distributor sub housing. the inside of your subhousing was probally rust color
Old Jul 18, 2002 | 07:46 PM
IN VTEC's Avatar
Default Re: distributor fork (minime)
I concur on the full, uninhibited rotation of distributor shaft.
minvi
Mar 7, 2011 06:04 PM
