F22 to replace H22?
Old Jun 30, 2008 | 12:07 PM
StockDC2's Avatar
Default F22 to replace H22?
I was wondering if I could use the F22A Motor and Tranny to replace my current H22 Motor and Tranny. Will it be a direct drop in? Anything that I need to change? Thanks and let me know.
Old Jun 30, 2008 | 12:18 PM
LwdJdmR's Avatar
Default Re: F22 to replace H22? (StockDC2)
from what ive researched, the F and H series are the exact swap.
Old Jun 30, 2008 | 01:24 PM
Syndacate's Avatar
Default Re: F22 to replace H22? (LwdJdmR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LwdJdmR &raquo;</TD></TR><TR><TD CLASS="quote">from what ive researched, the F and H series are the exact swap.
Agreed, it's basically the same thing, just double check to make sure the F series has a cable shift setup instead of a linkage.
Old Jun 30, 2008 | 02:43 PM
CivicSpoon's Avatar
There's also a little wiring difference. There should at least be 2 wires that need to be swapped at the ECU, one being an O2 sensor wire.
Old Jun 30, 2008 | 10:15 PM
StockDC2's Avatar
Default Re: (CivicSpoon)
I already have another O2 sensor for the H22. Do you mean that I need to swap them around or that I need to get one put in?
What's the difference between a cable shift and linkage? The motor that I am getting goes into 90-93 Accords and 92-95 Preludes.
Old Jun 30, 2008 | 10:38 PM
denraweb's Avatar
Default Re: (StockDC2)
dont the f22's have an external coil for the distributor? I say that 'cuz when we swapped my cousin's accord to h22, we had to use the old external coil on the h22 to start the car until we re-wired a little...
As for the mounts and all that stuff, as long as they are both 5 speed or both automatics, it will be a direct drop in.
Old Jul 1, 2008 | 07:31 AM
CivicSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I already have another O2 sensor for the H22. Do you mean that I need to swap them around or that I need to get one put in?</TD></TR></TABLE>
Nope, just one of the wires for the O2 sensor is in a different pin of the ECU.
http://www.accordinglydone.com...?t=29
You need to switch the wires of A6 & A11. With the H22A ecu (P13), A6 is an O2 sensor wire & A11 is a wire for the EGR, but with the Accord ecu, A6 is an EGR wire & A11 is an O2 sensor wire.
Old Jul 1, 2008 | 06:38 PM
StockDC2's Avatar
Thanks for the info! I have a chipped P28 so I'm guessing that the wiring is similar to the prelude one?
Old Jul 1, 2008 | 07:24 PM
CivicSpoon's Avatar
Yup. You shouldn't need to do any wire switching then.
Old Jul 1, 2008 | 07:42 PM
japspecb7's Avatar
90-93 f22 trannies use different mounts from 96+ f22 trannies. But all h22 trannies use the same mounts as 96and up f22 trannies. so get you mounts right. as for everything else, no wiring what so ever.
Old Aug 23, 2008 | 10:33 PM
StockDC2's Avatar
Default Re: (japspecb7)
Thanks for the info guys. I just attempted to do the wiring and have found multiple connectors that are not connected to anything, a few which are supposed to be plugged into the dizzy. The dizzy in the F22A1 is external, and the H22A is internal. If what you guys are saying is correct about the wiring harness not needing any changes, can someone point me in the right direction on doing an external to internal coil swap? Thanks.
SUPERSONICGSR99
Feb 4, 2007 05:44 PM
burplelude
Jun 9, 2006 10:40 AM
mikecivichb
Sep 1, 2005 02:28 PM
TypeRobert
Aug 20, 2005 09:00 AM
301am
Nov 4, 2004 11:57 PM
