Lower Arm ball joint is spinning, is that normal?
Old Jun 30, 2008 | 09:11 AM
Niskyspy's Avatar
Default Lower Arm ball joint is spinning, is that normal?
Well, I was replacing an axle in my GF's 95 integra. When I got to the end I started to tighten Lower Arm ball joint castle nut, but it wouldn't tighten because the ball joint would spin. Is this normal? Should I replace the whole assembly? Is it safe to drive the car if I tighten it as much as I can, and put the cotter pin in?
Thank you.
Old Jun 30, 2008 | 09:42 AM
qazaq's Avatar
Default Re: Lower Arm ball joint is spinning, is that normal? (Niskyspy)
yes it is normal, and there are tons of threads of how to go around it. search
Old Jun 30, 2008 | 05:40 PM
Niskyspy's Avatar
Default Re: Lower Arm ball joint is spinning, is that normal? (qazaq)
I searched and all the topics I found were saying that this isn't normal and that ball joint should be replaced.
Old Jun 30, 2008 | 06:02 PM
all-mtr-teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Niskyspy &raquo;</TD></TR><TR><TD CLASS="quote">I searched and all the topics I found were saying that this isn't normal and that ball joint should be replaced. </TD></TR></TABLE>
There's your answer, why'd you have to start a new thread?
Old Jun 30, 2008 | 06:27 PM
RGoose18's Avatar
Default Re: Lower Arm ball joint is spinning, is that normal? (all-mtr-teg)
It IS normal
Just jack up the LCA and then tighten the bolt
Old Jun 30, 2008 | 06:29 PM
bakertime's Avatar
As your ball joint becomes used it is more prone to moving. If you picture what a ball joint actually is, it makes sense. It's just a ball in a socket, with a bolt coming out of it. If the ball itself (the screw) is spinning, then thats ok as long as the ball doesn't have play up and down (you can use a pry bar to check this). To avoid it spinning, you'll need to put a good amount of pressure down on it while you remove the castle nut. Try pushing with your hand, or get creative with a jack or clamp. Sometimes having an extra person to apply pressure helps too. My tie rods did this, but only required a little pressure from my hand.
If you decide to replace, you're not replacing anything other then the ball joint, which needs to be pressed in/out. You're still going to have to get the nut off though. If you decided to go that route, you can tear the bushing and grab it with vice grips. Once you remove the knuckle you'll need a ball joint c-clamp or press to pop the old one out and the new on in.
If you need a c-clamp, I've got one for rent! Just did mine a few weeks ago...
http://www.hondacivicforum.com/m_595103/tm.htm
Good luck!
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
90CivicDaily
Jun 4, 2008 04:39 PM
mikekc99
Jun 13, 2007 10:42 PM
squeaky
14
Aug 29, 2004 12:08 PM
87_accord_lx
Jun 22, 2003 08:44 AM
