z6 head on y7
Old Jun 30, 2008 | 08:22 AM
SuperTuner12010's Avatar
Default z6 head on y7
A friend of mine has a 2000 civic hatch with a d16y7. He wants my d16z6 head, and he wants me to do the labor. Although I dont know what all is heeded.
His car is OBD2 right? And he doesnt have the money to convert to obd1. So I was thinking of putting the head on and using the y7 dizy? Would that work...
Also what ECU would work? A z6 head gasket will work right?
Old Jun 30, 2008 | 08:56 AM
wmac's Avatar
p28 ecu is best for z6 head
also reccomend z6 intake manifold/sensors/injectors
y7 dizzy will not work with z6 head and is OBD2
if you don't want to do the conversion, look for a y8 head, and intake manifold, and ecu
Old Jun 30, 2008 | 11:14 AM
justinCO's Avatar
Default Re: (wmac)
You'll also need to add wires for vtec.
And you'll need a different head stud by the vtec solenoid (a z6 one).
IMO it will be more work then what's it worth. You won't notice much of a difference w/ the vtec head.
Justin
Old Jun 30, 2008 | 07:05 PM
Default Re: (justinCO)
He has the d16y7 in his car now, and I have a full z6 head. He wants it, and I want to get it going for him.
Wiring vtec is easy. He wants to stay obd2 so is there any obd2 dizzys that will work or whitch one should I use?
Also what OBD2 ecu would work with it?
Old Jun 30, 2008 | 08:12 PM
justinCO's Avatar
Default Re: (SuperTuner12010)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTuner12010 &raquo;</TD></TR><TR><TD CLASS="quote">He has the d16y7 in his car now, and I have a full z6 head. He wants it, and I want to get it going for him.
Also what OBD2 ecu would work with it?</TD></TR></TABLE>
Obd2 dizzy will not work, I just went through this on my car. You need an obd1 dizzy, or at least the obd1 dizzy "casing" and put in obd2 internals.
For obd2 ecu you would probably want an EX manual ECU, p2p. I just happen to have one for sale
https://honda-tech.com/zerothread?id=2321532
Don't forget you'd need a z6 stud too, lightningmotorsports.com I think it is sells custom ARP head stud kits for exactly what you're doing. Or you can just get the y7/y8 headstud kit and order a single z6 stud from ARP, that's what I did.
Here are my notes from my research:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
d16z6 cylinder head on y8/y7 block:
- - 9 Y8 Headstuds - 1 Z6 Headstud in the top left corner by the vtec solenoid. No extra modding. (Z6 stud may need 1 extra washer).
- - z6 head stud is slightly longer
- - Use Z6 cam and cam gear with Z6 dizzy with y8 internals.
- - y8/z6 tbelt
- - Z6 head requires Z6 or Z1 Dizzy.
- - Y8 Headgasket
part number for a z6 stud is AM 6.450-1LB
Justin
88EFsedan2
Mar 24, 2012 09:59 PM
vital123
17
Dec 22, 2009 06:04 AM
98civM0bbin
17
Aug 4, 2007 03:35 PM
Civic98KH
May 16, 2007 09:16 AM
yz125rider21
Dec 10, 2005 09:31 AM
