Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Weak Handbrake
Old Jun 30, 2008 | 08:07 AM
Killtodie's Avatar
* B A N N E D *
Default Weak Handbrake
my hand brake is kinda weak. keeps the car from going anywhere when parked but I can easily drive off with it engaged and it doesnt do much when I pull it at low speeds.
drums in the rear recently replaced, had the same problem before though.
i adjusted the brake cable from inside, but that doenst help much. is there anything else I can do to make it grip better?
Modified by toyomatt84 at 11:19 AM 7/7/2008
Old Jul 2, 2008 | 06:56 AM
K24_Y61P's Avatar
Default Re: (Killtodie)
Try twisting the washer I drew the arrow to. Sorry if the arrow is hard to see. I have twisted that washer to expand the shoes to adjust my break always. It has worked for me.
Old Jul 2, 2008 | 07:30 AM
Killtodie's Avatar
* B A N N E D *
thats good, thanks
can anyone link me a diy for working with rear drums?
Old Jul 2, 2008 | 08:27 AM
gwapocivic's Avatar
When properly adjusted you should only be able to pull the E-brake up about 5-7 clicks.
If you have adjusted it at the handle and it doesnt work, check the adjustment screw refered to in the one post. You will turn it to either pull the shoes in, or push them out. I am guessing if you take the tire of you can spin the drum very easily. With properly adjusted drums their should be a very lite drag on the drums from the shoes. As time goes on and the wear down they need to be adjusted to ensure proper braking.
When you get the drums adjusted you will most likely have to re-adjust the E-brake as it will be to tight.
Good luck and hope this helps.
Old Jul 2, 2008 | 10:11 AM
Kongo69's Avatar
566 posts and you still cant search?
Old Jul 17, 2008 | 04:24 PM
recaroem2's Avatar
Default Re: (civ_nate)
i hate drums to hard to work with. thats why i switched to disks. made jdm yo. lol
Old Jul 17, 2008 | 04:27 PM
Curiouz_G's Avatar
made jdm. lol sorry but that made me LOL at work
PreludePhill
May 5, 2006 07:22 AM
lilman4o8
Jun 9, 2005 07:33 AM
cash459
May 26, 2003 04:56 PM
91_hatch_si
Apr 28, 2003 05:21 AM
MRSI00
Jul 11, 2002 02:49 PM
