Crossmember..can i ditch it?
Old Jul 18, 2002 | 05:59 PM
SpeedMonkeyRacing's Avatar
Default Crossmember..can i ditch it?
What exactly does crossmember do? I recently got a b16 swap and don't have the front mount on it....do i have any use for it?
Jeff-
Old Jul 18, 2002 | 06:02 PM
StorminMatt's Avatar
Default Re: Crossmember..can i ditch it? (Corporal-Jeff)
I wish I could just ditch it. But you can't. The crossmember both gives the front end of the car structural support and provides mounting points for the radius rods. If you need more room up front, you can buy a custom crossmember.
Old Jul 18, 2002 | 06:06 PM
turbohf's Avatar
dude that is funny as hell, i was just thinking this two seconds ago. but yeah it has to be there like Matt said...
Old Jul 18, 2002 | 06:19 PM
89 CRX SI's Avatar
Default Re: Crossmember..can i ditch it? (turbohf)
sure just cut a nbig ***** out of it
hahahaah JK
DUDE I WAS JOKING>...................... PLEASE DONT DO THIS>.....................
Old Jul 18, 2002 | 07:11 PM
Soled Out's Avatar
Default Re: Crossmember..can i ditch it? (89 CRX SI)
i cut a big chunk out of my old crx crossmeber so my header wouldnt rub..it worked ok
civbeater90's Avatar
um only if you want to crash.
Old Jul 18, 2002 | 07:52 PM
Mugen Dom's Avatar
Default Re: Crossmember..can i ditch it? (civbeater90)
lots of wheel hoop to
Old Jul 18, 2002 | 10:35 PM
RexB16's Avatar
Default Re: Crossmember..can i ditch it? (jdmB18hatch)
oh man, why would ANYONE even ask this? hey can i remove my radiator? it just sits there and gets in the way...
Old Jul 19, 2002 | 04:48 AM
Default Re: Crossmember..can i ditch it? (RexB16)
i ask because i didn't see the point of it since other hondas don't have 'em.
i swear, there always some smart *** thinking he's the **** and knows everything.
WHY POST IF YOU DON'T HAVE ANY PRODUCTIVE TO SAY?
Jeff-
Old Jul 19, 2002 | 06:40 AM
91sifreak's Avatar
New User
Hey check this out, My father in law and I were looking at the crossmember and he is a 30 year vet to working on all kinds of cars. Now he says that if you take some good aircraft grade metal and weld it on to the crossmember in a area bigger then where you want to notch it out for the header, then cut the area out and then weld in the seams it will hold perfect, I think i am going to try this so I can get the jdm 4-1 ITR header in there. I think this will work, letcha know how it goes.
Old Jul 19, 2002 | 08:01 AM
RexB16's Avatar
nah, honda just stuck that on there for kicks right? the reason newer hondas dont have them is b/c honda has stiffened the chassis accordingly.
Old Jul 19, 2002 | 08:06 AM
well, wouldn't this answer be much better than the one you posted earlier? thanx anyway...
Old Jul 19, 2002 | 08:14 AM
virginia_dude's Avatar
He asked this since obviously he has never looked under his car, or it would be self explainitory. since the radious arms clearly go between the lower control arms and the crossmember. And front mounts and front cross members are totaly different animals. I think he meant to ask about the front mount and not the front cross-member. At least that would make more sense.
[Modified by virginia_dude, 12:15 PM 7/19/2002]
[Modified by virginia_dude, 12:18 PM 7/19/2002]
[Modified by virginia_dude, 12:19 PM 7/19/2002]
Old Jul 19, 2002 | 10:12 AM
Default Re: Crossmember..can i ditch it? (virginia_dude)
actually...what i tried to ask is that if i can modify the crossmember so my 4-1 header could go in.
Jeff-
Old Jul 19, 2002 | 11:07 AM
dustin's Avatar
Old Jul 19, 2002 | 02:38 PM
BoostedED9's Avatar
Default Re: Crossmember..can i ditch it? (dustin)
nice work, you weld it yourself???
Old Jul 19, 2002 | 02:42 PM
dustin's Avatar
Default Re: Crossmember..can i ditch it? (ED9Hybrid)
It's jeremy's subframe
he welded in my garage with my welder, though
Old Jul 19, 2002 | 05:05 PM
kyler's Avatar
damn.... now thats a crossmember done right
Old Jul 19, 2002 | 06:46 PM
slywfbpsi's Avatar
Default Re: Crossmember..can i ditch it? (kyler)
why not just use a z10 crossmember? They told me I could just ditch my factory crossmember after that.
Old Jul 19, 2002 | 07:27 PM
dustin's Avatar
Default Re: Crossmember..can i ditch it? (slywfbpsi)
Are they giving those z10 crossmembers away for free now?
hehe
Old Jul 19, 2002 | 07:32 PM
slywfbpsi's Avatar
no, but it'll get rid of your wheel hop and eliviate (-5sp) you from having to cut, or take a sledge hammer to your crossmember so, you can run a bigger header or downpipe.
Old Jul 19, 2002 | 07:48 PM
MR CRX's Avatar
but dont they cost around 500 bucks??
id rather take a hammer to it then spend 500 bucks unless it was absolutely necessary. just my opinion though
Old Jul 19, 2002 | 08:43 PM
4g4me's Avatar
crash and burn baby!!!!
Old Jul 19, 2002 | 09:08 PM
speeddave's Avatar
nice job on the crossmember, its nice to see some good fabricating
spun95
Welding / Fabrication
13
Oct 11, 2011 09:53 PM
3rdshift
Sep 3, 2009 03:58 AM
rex714
Jun 9, 2009 02:46 PM
boosted6
Oct 13, 2005 04:36 PM
sCeRaXn
13
Jul 29, 2003 01:26 PM
