Door panel
My drivers side window is going up a little crooked so i attempted to take the door panel off to see if the rail is bent or something. Does anyone know or know where i can find out how to take the door panel off my type s. I can get it all off except for the part thats attatched at the door handle.
Yea i got the 2 screws that go in around the armrest and then pryed off all the panel except for the actual handle you pull to get out of the car with. I cant figure out how to get the panel apart from the door handle.
Pop the cover off with a tiny flat head screwdriver, remove 2 screws and latch line. You should be able to see the tab to take the panel off the door handle.
If you end up breaking it and have tan interior, hit me up. lol
If your problem is the same as mine with the windows "falling forward" it's because of the stripping inside the pillar not the regulator. Use some grease in the window channel and avoid closing your window at highway speeds.
My accord had the same problem. I tried everything to fix it: new motor, regulator, lubed the channel. I eventually broke down and bought a new rubber channel. Worked perfect.
I'll post pics up if no one else does.
