How do you install an oil pan gasket so that it does not leak?
Old Jun 30, 2008 | 12:48 AM
nb0's Avatar
nb0
Default How do you install an oil pan gasket so that it does not leak?
I'm installing a new OEM acura oil pan and using a new OEM gasket. I'm going to use Permatex Sealant #2 (black color) instead of honda bond.
1. Do you put honda bond / sealant on both sides of the gasket? Or just apply it on top of the oil pan surface and then place the gasket on top of the oil pan?
2. Do you put honda bond / sealant all the way around the entire oil pan surface or only at the corners?
3. Will torquing it to 9 lb/ft cause the gasket to push out pass the oil pan lip?
I'm going to tighten the bolts according to the helm manual cross pattern.
Old Jun 30, 2008 | 06:36 AM
tegra2G's Avatar
ya just got around the seal with the sealer. make sure you scrape off all the old **** from the block, *** long as you follow the torque sequence its works out fine. just take the sealer around the hole thing, not to much though
Old Jun 30, 2008 | 08:05 PM
96lsvtec-t's Avatar
Default Re: (tegra2G)
+1
Old Jun 30, 2008 | 08:10 PM
all-mtr-teg's Avatar
Default Re: How do you install an oil pan gasket so that it does not leak? (nb0)
I use the permatex grey, comprable to hondabond for 1/3 the price.
Old Jun 30, 2008 | 10:13 PM
nb0's Avatar
nb0
Old Jun 30, 2008 | 11:02 PM
integ401's Avatar
you don't need any sealer because it gives you a rubber gasket. Just start tightening bolts in a circle. Thats it
B_Swapped93
Nov 17, 2014 08:56 AM
Romodavid15
Mar 16, 2010 08:16 AM
phelpsj2
Mar 9, 2010 12:16 PM
miro_gt
Jun 24, 2007 08:02 AM
htownteg
Jan 30, 2004 07:15 PM
