d16a1 swap. into my civic
Ok so i started the swap today and ran into problems. i knew i would and i found out what they are already lol. well here are a couple pics to start it off,
well heres a stock cam gear side mound i tried fabbing but it was all outta wack
it sat way too high and crooked
so im going to have to make one like everyone else. not a hard job tho
here is Nihad form h-t helping me out on the motor cause im a learning honda noob
using the censers from the d15 on the d16
here are a couple random shots of the motor and car
i dont get how this is happening im using a stock 90 si tranny
......updates coming soon
Modified by tyler100 at 8:54 PM 7/31/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nampicuan »</TD></TR><TR><TD CLASS="quote">I dropped the passenger side of the cross-member and an extension with a universal joint</TD></TR></TABLE> thanks. ill tey that tonight mabe. anyone else have any other way?
remove the other 2 bolts then hit the mount and knock it sideways and you can access the rear bolt. or use 2 swivel joints and an extension and you can get at it.
i might do it like this<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">remove the other 2 bolts then hit the mount and knock it sideways and you can access the rear bolt. or use 2 swivel joints and an extension and you can get at it. </TD></TR></TABLE>
heres a pic of the mount on the car.
under the mount
motor in and level
wiring up the auto to manual
HA sleeper ( j.k ) got me a stock **** already
oh and heres some flooding tried saving my civic and not the teggy lol
caught this bad boy in my drive way. i dont even live very close to a river.
this was from a creek kinda far from my house.
will get more of putting it together when it comes around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpwagon »</TD></TR><TR><TD CLASS="quote">very interesting. not many people put that integra motor in the civic. </TD></TR></TABLE>
x2
x2
i ran into a problem today. when doing my mpfi swap i need to connect the 2 wires to the dizzy. well i cant use a si dizzy cause there different. on how they bolt on. the a1 dizzy is just like the dpfi dizzy 5 wires. do i need to get a 89 teg ecu to fix this?
Do i need to need to use the distributor connector from the A1 harness on the dx harness and extend the Cylinder Sensor wires to the sensor on the end of the exhaust camshaft
you need 88-89 (not 86-87) Integra distributor - the A1 and DX distributor connectors are identical - if you haven't already swapped connectors, just leave the DX connector which plugs right in - run/extend wire from ECU pin C1 to the blue/green wire on the Cylinder Sensor - run/extend wire from ECU pin C2 to the blue/yellow wire on the Cylinder Sensor - use the 88-89 Integra PG7 ECU - don't try to use 86-87 Integra PG7 ECU - it won't work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyler100 »</TD></TR><TR><TD CLASS="quote">its a 89 a1. and i figured it out. will the pm6 ecu work? thats what im running for now. just stock si. </TD></TR></TABLE>
yes it will work and run but not to its potential, I would source the 88-89 teg ecu
imlooking for the ecu now. calling junkyards. does anybody know if a crx exaust will fit on a ef civic? i have a dnx midpipe and the rest until the axle back but the rest of it dont look like it lines up./
please let me know how this works out. Theres this exact setup for sale but the guy put the motor in ran some wires and he's got no spark. I'm very interested on the specifics of this swap in relation to the wiring,
hey Kool0adi is there any way i could see the set up? like a link or something. i have only seen a couple pictures of the swap but not good ones. mabe he is running the vacc advanced dizzy.?
