starting issues.
Old Jun 29, 2008 | 08:27 PM
detuned's Avatar
Default starting issues.
Searched, couldn't find anything substantial to my problem.
Swapped a d16a6 into my '89 HF, been working fine. Idles nicely, runs nicely, no problems. Tightened up the clutch/flywheel cover on the bottom of the block/tranny and it proceeded to not start. I turn the key in the ignition and the fuel pump kicks in and primes the rail. Main relay not an issue at this point. However, when I turn the key to start the car, nothing happens--the dash doesn't click out and no relays hit. Wondering which relay and the location for the starter. Starter is fine, haven't had any problems with it, jumped it outside the car. Wanting to know if it's a bad relay somewhere or a possible wiring problem/something worse.
Any help is appreciated.
Old Jun 29, 2008 | 08:47 PM
black0hatch's Avatar
Default Re: starting issues. (detuned)
i dont think theres any realays for that. its probably your ignition switch. try a spare one if you got one or one off a friends car. it screws into the back of the ignition lock where you put your key then theres 2 plugs. can you start it with a screwdriver on the starter or push start it?
Old Jun 29, 2008 | 09:13 PM
detuned's Avatar
push starts fine. i'm thinking it's most likely the ignition switch. i'll try the screwdriver tomorrow. thanks for the tip!
Old Jun 30, 2008 | 05:34 PM
Default Re: (detuned)
if it push starts and you know for a fact the starter is good then dont bother with the screw driver. im gona bet its your ignition switch.
Old Jun 30, 2008 | 08:26 PM
detuned's Avatar
yeah it is. getting another one from the salvage yard pretty soon. for now i'm gonna run heavy gauge wire from the two leads and have my ignited engine start button do the trick.. but i'm hiding it so i don't get my **** jacked.
thanks for the help.
Old Jul 1, 2008 | 08:55 AM
haha i bought a crx once that had the same problem and the dude wired a push button start too. only he didnt hide it it was right next to the shifter.
Black R
Apr 8, 2023 07:14 AM
DaiSeeFut
Oct 31, 2012 04:51 PM
91tegrals
Feb 12, 2012 09:03 PM
SuperTuner12010
Nov 22, 2008 08:42 AM
ef9_pr0jekt
Oct 7, 2007 06:15 PM
