First EVER aluminium welds
Old Jun 29, 2008 | 05:52 PM
KNS Autosport's Avatar
Default First EVER aluminium welds
Alright so I picked up this KOYO radiator off ebay for a More than Fair price but the lower water neck was on the opposite side of where I needed it to be, I decided I would try my skills out on this piece.
What do you guys think ?
and the plugged hole
Old Jun 29, 2008 | 07:42 PM
SD_Lurker's Avatar
HT White Ops
Default Re: First EVER aluminium welds (KNS Autosport)
Its not the best looking welds but as long as it serves its purpose then who gives a ish? Aluminum isn't easy to weld let alone make the welds presentable.
Old Jun 30, 2008 | 02:41 AM
jzz30's Avatar
those welds look better than some things that are sold to the public.
Old Jun 30, 2008 | 07:59 AM
chimmike's Avatar
Default Re: First EVER aluminium welds (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote">Its not the best looking welds but as long as it serves its purpose then who gives a ish? Aluminum isn't easy to weld let alone make the welds presentable. </TD></TR></TABLE>
exactly what I was thinking. It ain't perfect looking but does look like it'll do the job just fine.
Old Jun 30, 2008 | 10:16 AM
qksl2's Avatar
Default Re: First EVER aluminium welds (chimmike)
Great job for your first time. Aluminum can be either fun or a nightmare to weld, depending on cleanliness or fit.
Ian
Old Jun 30, 2008 | 05:24 PM
Thanks for the reply, any tips on making a "better looking weld"
Old Jun 30, 2008 | 07:13 PM
SPROCK3T's Avatar
Default Re: (KNS Autosport)
practice, and arc length...
Old Jul 1, 2008 | 10:58 AM
roadracer4life's Avatar
look great to me.
Old Jul 1, 2008 | 03:56 PM
92exaccord's Avatar
clean tungsten, clean aluminum by running over it with welder before welding.
main thing with aluminum is clean, clean clean
Old Jul 2, 2008 | 05:43 AM
awill4x4's Avatar
Default Re: (92exaccord)
Like all welding it's practice, practice, practice. Where you have welded in the plug where your outlet was originally your welds are too hot and your travel speed too slow.
Aluminium is difficult in that when it starts to get hot it gets hot really fast, you need the heat to start the pool but then it all gets interesting very quickly.
I do a lot of ally welding with 1.6mm wire but in case like that I'd go to 2.4mm and use the extra mass of the wire to "cool" the weld pool and keep it more controllable.
I don't know what type of Tig machine you used but if it's a modern inverter machine I would be upping the AC hertz frequency to 150-175 Hz and pushing the AC balance further to the penetration side to get a nice tight arc for welding the outlet tube.
As you use a tighter arc you will need to up your amperage to compensate for the changes.
Start welding about a 1/4 of the way around the tube below the header plate assembly approx where the centre of your arrow is(assuming you're right handed and welding clockwise) this allows you to weld around the tube building the heat up as you go towards the header plate. The header plate is thicker and sucks up the heat and cools the weld pool preventing it from overheating, the last 1/4 has had a lot of heat sucked out by the header plate so it shouldn't overheat even though it's thinner.
Regards Andrew from Oz.
Old Jul 2, 2008 | 07:46 AM
JayPee_inc's Avatar
looks pretty damn good to me
BelgiumEG6
Honda Motorcycles
48
Sep 25, 2007 05:17 PM
whitegsr-t
Jun 28, 2007 07:03 PM
quackattack
Apr 15, 2007 01:54 PM
g2turbo
Oct 9, 2006 12:06 PM
Matty.
Honda Motorcycles
22
Oct 14, 2005 07:51 AM
