Third gear "jumping" out , S80 gear in 98 hatc
Old Jun 29, 2008 | 05:19 PM
magefa's Avatar
Default Third gear "jumping" out , S80 gear in 98 hatc
Hey guys ,
i have a 98 hatch with b16a2 swap and S80(lsd) hydro gear.
i had problems with the synchro's in the gear, i orderd new ones
but did not install them yet.
latly (about 2weeks) the thirds gear "pops out"
does that means i have to replace all this parts in it?:
what should i check , or how can i assume what is the problem without opening it up?
TIA For any help!
Old Jun 29, 2008 | 05:26 PM
nub's Avatar
nub
Default Re: Third gear "jumping" out , S80 gear in 98 hatc (magefa)
Popping out of gear is usually worn syncros, not to say there isn't damage to the gear itself. As far as I know the only way to know for sure is split it open.
Old Jun 29, 2008 | 05:27 PM
vtecb18c's Avatar
Default Re: Third gear "jumping" out , S80 gear in 98 hatc (nub)
yea you have to take it apart but the gear is probably shot by now
Old Jun 29, 2008 | 05:39 PM
gsrhatch2356's Avatar
Not trying to correct anybody or anything but first off if the synchro was bad then it would grind so if it dosent then theres nothing wrong with the synchro. and if you can still get into and out of the gear with no problem then more than likely the gear it self is good. if you notice the rings that go onto each synchro those are blocking rings and they keep the synchro in gear so if you replace those then you should be good as long as you arent experincing any other problems.
Old Jun 29, 2008 | 05:53 PM
magefa's Avatar
Thnx for the answers guys ,
the problem is that where i come from (Israel)
idont have the availability of parts for any "unique" parts (yeah b16/integra parts = unique and close to none!)
so if i just open the gear and see whats wrong i'll have to wait a week+ just to order and get the parts from abroad.
so what to you guys think?
should i just buy this sleeve set?
http://www.gearspeedinc.com/pr..._Sets
TIA again..
Old Jun 29, 2008 | 06:44 PM
2redstars's Avatar
did you make sure the fluid level is correct? low trans fluid will do this also
Old Jun 30, 2008 | 02:06 AM
magefa's Avatar
Default Re: (2redstars)
You mean the oil level?
I think i dont have a clue on how to check the oil level in the gear, never done it before...
Old Jun 30, 2008 | 03:15 AM
2redstars's Avatar
id start there then, drain your fluid, then add some honda mtf.
theEGGmonsta
Jun 1, 2010 08:24 PM
gray_civic_coupe
Sep 16, 2005 01:15 PM
