Bought another ef civic, HELP Please
Old Jun 29, 2008 | 04:09 PM
90 Si Hatch's Avatar
Default Bought another ef civic, HELP Please
well i bought another civic dx it had an ls-vtec in it for $2000. well the ls-vtec spun a rod bearing the guy said, so i pulled the motor and put a b20 into it just for something else to drive. well its all in and for the past 2 days i've had problems getting it to start. the fuel pump wont prime. i've done everything and cant find the problem. well i ran a wire from the fuse box to a inline fuse to a switch and then to the fuel pump. now its getting fuel to the injectors but i find out now that the injectors aren't spraying. i made sure all 4 were working by jumping each to the battery and they clicked. so i must have a big problem on my hands. thought it was just the fuel pump but its the whole fuel system now.
1989 civic DX
B20 motor
OBD0 to OBD1 conversion harness
P72 ecu
it turns over, and it will start if you spray gas into the manifold with a bottle.
SOME ONE PLEASE HELP
jsut thought i'd put these in here....
Old Jun 29, 2008 | 05:21 PM
1991civicsi's Avatar
main relay?
Old Jun 29, 2008 | 05:57 PM
zrickety's Avatar
Default Re: (1991civicsi)
sounds like the jumper harness or ecu...if it was running before, it's something you put in or wired up. seems the ecu is not sending the signal to the fuel pump or the injectors. not saying it's not the main relay, but if it ran before that's probably not the cause
Old Jun 30, 2008 | 05:06 AM
Default Re: (zrickety)
i've itied 3 different main relays all worked but one, and i tried my p28 ecu from my other civic and the still the same thing....
Old Jul 2, 2008 | 06:55 PM
Default Re: (90 Si Hatch)
Well come to fine out, there is a short in the key switch. Its still not fixed but it runs now thats all i care. no work tomorrow so ill get it fix....
civicef990
10
Nov 10, 2010 11:04 PM
rzecca
Classic Hondas
Jun 21, 2010 06:11 PM
89vwfox
Feb 4, 2009 08:10 AM
89vwfox
Jan 31, 2009 11:54 AM
b20turbojason
Oct 5, 2003 06:44 PM
