idle problem,.....continued.
Old Jun 29, 2008 | 03:05 PM
JdelMsolG's Avatar
Default idle problem,.....continued.
so i've been having a pretty shitty run at work, busy as hell.
in the mean time, my cars been sitting in the driveway with an idle problem, finally got around to playing around with it, doesnt seem to be any leaks anywhere, the problem has seemed to get better after letting the car warm up for a few minutes, now the idle bounces from about 200 to about 800 non-stop. Smells like the car is running really rich, and theres an odd tapping noise under the hood...almost sounds like its coming from the injectors. Could bad plugs possibly cause a "tapping" sound?
Old Jun 29, 2008 | 03:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: idle problem,.....continued. (JdelMsolG)
unplug the iac and tell us what happens.
Old Jun 29, 2008 | 03:13 PM
4drkidd's Avatar
Could be:
- Vacuum Leakage
- Leaking EGR valve
- Clogged air filter
- Fuel pump not delivering sufficient fuel to the fuel injection system
- Leaking head gasket
- IACV issue
- Camshaft lobes worn
- Timing belt and/or pulleys worn
Old Jun 29, 2008 | 03:34 PM
JdelMsolG's Avatar
Default Re: (4drkidd)
whats an egr valve?
appreciate any input.
Old Jun 29, 2008 | 04:11 PM
JdelMsolG's Avatar
Default Re: (JdelMsolG)
bump, would a video help?
Old Jun 29, 2008 | 04:26 PM
4drkidd's Avatar
EGR - Exhaust Gas Recirculation
Check the hoses, the EGR valve lift sensor and the System EGR valve.
Are you having a CEL?
Old Jun 29, 2008 | 04:37 PM
JdelMsolG's Avatar
yeah but only for knock sensor i think. and that makes sense but that wouldnt cause an idle issue would it?
Old Jun 29, 2008 | 06:39 PM
JdelMsolG's Avatar
bump for morning, tomorrows my only day off this week, gotta figure this **** out.
Cardinals87
Sep 21, 2016 07:24 PM
b16a4
Sep 5, 2007 05:23 PM
211811518
Sep 18, 2006 04:15 AM
Cincy98lude
Feb 28, 2005 12:41 AM
maxxdout
Jun 21, 2002 06:04 AM
