B20b or B18a1 Ls pistons?
Old Jun 29, 2008 | 11:28 AM
92hondaswap's Avatar
Default B20b or B18a1 Ls pistons?
I have a '93 B18a1 engine on a '92 civic hatch. I just bought a '99 B16 Vtec engine but I wanna make it Ls Vtec-Turbo. So my question is which Pistons are better for Turbo application, B18A1 pistons or B20b pistons?? I'ma get rid of the B16 pistons cuz they aint no good for me for turbo... I saw some B20b pistons on ebay, some were with dome and some were flat head.
Old Jun 29, 2008 | 11:38 AM
AltimaXX's Avatar
B20 pistons are a different bore than B16/B18 pistons, so they won't work without the block having been bored to match.
Old Jun 29, 2008 | 11:41 AM
Default Re: (AltimaXX)
what about the B18a1 pistons? do I need to bore the block as well for them to fit? weather I have to bore the block to fit the B20b pistons in the B16 block or not which pistons are better for Turbo is my Q's....
Old Jun 29, 2008 | 11:47 AM
AltimaXX's Avatar
No, B18A1 pistons will work without needing to bore the block. B18A pistons will make a ridiculously low compression number in an otherwise-B16A motor. (8.6, according to ZealAutoWerks compression calculator)
I'm going to let someone more knowledgeable answer your questions about which would be best.
Old Jun 29, 2008 | 02:54 PM
Brice.Hayden's Avatar
b16a = pr3 and p30
b16b = pct
b18a/b = pr4 and p75
b18c = p72
b18c5 = p73
all are 81mm
b20b and b20z are 84mm.
does that help?
Old Jul 5, 2008 | 09:41 AM
Default Re: (Brice.Hayden)
yes it does thanks!!!
Old Jul 5, 2008 | 09:50 AM
hey I put the specs of putting Ls pistons in a B18a block and it didn't give me no 8.6 comp. I'm not sure where its read but here's what I got> piston to deck height -0.096 , effective comp ratio 11.86, rod stroke ratio 1.77 @ a max operating RPM of 8000
Old Jul 5, 2008 | 10:00 AM
all-mtr-teg's Avatar
Default Re: (92hondaswap)
http://www.zealautowerks.com
use this to find what combo of parts will help you achieve your CR goal. Use the LS block with the b16 head, that'll keep you at 1.8 L.
Old Jul 5, 2008 | 10:25 AM
Default Re: (all-mtr-teg)
ok I guess I'm gonna have to use my 1.8 block and do Ls Vtec that way, I thought I could keep it 1.8 using the B16a block if I were to put on a LS crank,LS Piston wit LS piston rods on that B16a block... Thanks for the Info by the way!!
GT500FTW
Engine Machining & Assembly
Jun 14, 2015 10:52 AM
JDMCIVIC919
Feb 9, 2012 06:45 PM
Triple T
Jan 28, 2003 09:31 AM
robhamaliuk
Jan 24, 2003 10:17 AM
tysir
Aug 16, 2001 08:32 AM
