93 se overheating!!!!!
my wife has a 93 accord...lately its been overheating...i have 2 add water daily...so far ive replaced the thermostat,upper and lower hoses,radiator and cap...still overheats...2day we left the car running and it drained all the coolant somewhere below the intake pipe...the lower hose was wet but the clamp was on there tight...anyone know what it can be?
there are a few more smaller hoses that sometimes get little punctures and leak only when the car starts to reach operating temp
I suggest replace them all
Check out the fans and switches to see if they power on
Also bleed out all the air from the coolant if you have air in there the fans wont power on
I am sure you have checked the water pump seal. I had a similar problem (there was a small leak in the water pump seal) and had to replace coolant periodically.
Wish you luck!
Wish you luck!
Integritycaptain90
Jan 6, 2008 07:31 PM
UltimX
12
Jan 18, 2007 03:18 PM
Morning Call
Mar 17, 2005 02:44 AM
