B series Water pump interchangeability
I'm about to do a full tune up on a motor I just bought. It's a 97 B18b1. I was just wondering if I could use a water pump from other B series. Thanks alot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chef Andre »</TD></TR><TR><TD CLASS="quote">Thanks bud. Anyone want to confirm this?</TD></TR></TABLE>
yep thats all there is to it..
No, do not use an ebay kit especially for the water pump. I have the same year and engine as you and what you should do is get a 97' GSR water pump, timing belt, tensioner, spring, tensioner bolt. All in all it cost me around $200 and I did it myself. It fixed my issue of a squealing water pump bearing. Make sure to clean the corrosion up from where the water pump gasket goes. PM me if you have any issues during install because it was tough doing it for the first time by myself.
At the minimum, you need the timing belt and water pump.
The oil pump is optional, and the tensioner, spring and bolt are just additional maintenance.
Thanks for the help everyone. The motor is not in the car yet so everything should be pretty easy.
hmtcrxsir
Dec 30, 2008 08:00 PM
nasteawhun
11
Jul 21, 2008 02:19 PM
