So I have a ZC harness on my B18A1 in my EF and have 2 extra wires by the fuel injection wiring plug
Old Jun 28, 2008 | 01:10 PM
CorrodeONE's Avatar
Default So I have a ZC harness on my B18A1 in my EF and have 2 extra wires by the fuel injection wiring plug
One is Blue and the other is Black/Yellow... what are they for?
Old Jun 28, 2008 | 05:52 PM
CorrodeONE's Avatar
Default Re: So I have a ZC harness on my B18A1 in my EF and have 2 extra wires by the fuel injection wiring
nothin huh... maybe i should try another site.. have fun with you JDM aqura engine... oh wait, is there such a thing. ONE!
Old Jun 28, 2008 | 06:34 PM
godruler's Avatar
your problem is unless your using the harness that came with your trim model originally it is not going to work. So basically unless your car is a real ZC model originally you cannot use the ZC harness. if its an Si you have to use an original Si harness, if its an HF you have to use a HF harness, and if it was a DX you have to use an MPFI converted Dx harness. no ways around this that are worth the effort, do a little more research.
Old Jun 28, 2008 | 08:27 PM
93excivic's Avatar
if your ef is a si then, the extra two wiers is for a sensor that is behind the si manifold, I dont know whats the sensor called or what is it for but i think that might be it. GL
Old Jun 29, 2008 | 06:04 AM
MRN1120's Avatar
the blue and black/yellow are for the cylinder position sensor that the obdo zc has on the exhaust cam next to the dizzy.
Old Jun 29, 2008 | 09:17 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CorrodeONE &raquo;</TD></TR><TR><TD CLASS="quote">One is Blue and the other is Black/Yellow... what are they for? </TD></TR></TABLE>connector is for the Fast Idle Control Valve on the back of the SOHC intake manifold
Old Jun 30, 2008 | 01:58 PM
CorrodeONE's Avatar
So I do not need this sensor? the engine runs fine without it, 500 miles and still smashin..
Thanks for the responses just got a little baffled when I was pluggin in and saw 2 extra wires with no plug to pin them into... coluld have ripped open my harness and found out where they went but i just tucked them and forgot about them until i was pullin some leafs out from that corner and rememberd that they were just kickin it..
Do I need them on the B18A or can I just lock them off?
Old Jun 30, 2008 | 02:46 PM
jlicrx's Avatar
you don't need the wires - the 89-91 D16A6 had a Fast Idle Control Valve that boosted the idle slightly in very cold temperatures - that was it's only function
Old Jul 1, 2008 | 01:29 PM
CorrodeONE's Avatar
Awesome. I thank you very much for your help.
91tealhatch
Dec 29, 2005 06:11 PM
ivanson
14
Jun 6, 2005 10:27 AM
Dspad_91Civic
May 7, 2004 05:12 PM
RussHondaCRXVtec
May 12, 2003 08:16 PM
zccrx
Mar 23, 2003 02:50 PM
