Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
A/c question, need help
Old Jun 28, 2008 | 10:54 AM
MrXclusivE's Avatar
Default A/c question, need help
My a/c wasn't cold enough so I went to recharge it yesterday using one of those cans and I think I screwed something up, now every time the compressor engages it makes a little sucking sound, almost sounds like its got hick-ups, and rpm's fluctuate like crazy. Is this a sign of maybe air in the system or something? how can I check that?
Any Ideas on what it might be or how I can fix it? its a 2001 lx.
thanks
Old Jun 29, 2008 | 05:48 PM
MrXclusivE's Avatar
bump
Old Jun 30, 2008 | 08:25 AM
matt701's Avatar
Default Re: (MrXclusivE)
I overcharged mine while trying to diagnosis the problem and it did the same thing. I would let some of the freon back out. I believe running it with too much could actually lock up your pump and the RPM issue is because your car has to work harder to spin the pump. In any case i would not run your AC until you check your low and high side pressures.
Old Jul 8, 2008 | 01:26 PM
MrXclusivE's Avatar
Default Re: (matt701)
thanks, anyone know what should be the gauge reading for L and H side?
Old Jul 9, 2008 | 07:31 PM
MrXclusivE's Avatar
anyone?
also, how do I let freon out? from low side or high side?
Old Jul 9, 2008 | 07:34 PM
MrXclusivE's Avatar
and is the A/C suppose to be running when i do this?
Sammy24
Aug 19, 2018 01:18 PM
Jonathan_ED3
Jul 30, 2012 07:15 PM
mhonn
Jul 17, 2011 02:32 PM
jrs98
Oct 17, 2008 03:51 PM
forumnoobie
May 7, 2007 12:50 AM
