Help Help Help knock have no clue what
Old Jun 28, 2008 | 04:33 AM
ev_jonny's Avatar
Default Help Help Help knock have no clue what
ok i'm kinda new here i got a 94 ex coupe with jdm itr swap had it for about 3 month in the car, had to rebuild the trany syncros and now i got a problem
i can hear a ticking noise from the motor but not loud (i had d16 before and bottom end came out started knocking louder and louder untill i pulled it out well this sound is different but i'm scared ) it comes from the back part on driver side ,,first i thought maybe valve clearence since it older and probably been in ware house for a while got the specs for b18c1 from the dealer they didn't have the b18c5 or my b18c spec i figured it whould be the closest ,well done that got .17mm intake and .19mm exhaust still the sound didn't go away and the idle is whorse then ever i need help honda guys help
maybe someone had same or have any clue what it is
Old Jun 29, 2008 | 05:11 PM
vtecb18c's Avatar
Default Re: Help Help Help knock have no clue what (ev_jonny)
well injector pulses can sometimes sound like valve taps but it could be worse and be a rod bearing...does it get louder as you drive?
Old Jun 30, 2008 | 06:15 PM
ev_jonny's Avatar
Default Re: Help Help Help knock have no clue what (vtecb18c)
no it doesn't and also it sounds like ticking noise and the rpm jump from normal 8-900 to 1600 then it seems like it chokes over at 4000 rpm almost no power it kinda dies over there // how can i check the injectors should i unplug them pull them out connect them to their connectors and try to start it up and see if it sprays ? or how can i because it seems like it comes from alternator or smthn but i got told that alternators don't knock they eather work or don't
Old Jul 1, 2008 | 09:31 AM
citrus3000psi's Avatar
Sounds to me like something didn't get hooked up correctly when the transmission was reinstalled. I dont think your real problem is with the tick but the fact it won't rev over 4k.
Does the ecu throw any codes?
dillonsi
Jul 26, 2008 09:51 AM
Desperado
Apr 23, 2006 12:38 AM
aka Paco
Apr 23, 2006 12:36 AM
Doogie Howser
Jun 14, 2002 12:08 AM
