Headlight piezo buzzer problem
Old Jun 27, 2008 | 10:06 PM
FieldGenEJ's Avatar
Default Headlight piezo buzzer problem
I tried both ways to do this from the FAQ(squeezing wires behind fuses, actual unused plugs on top)
https://honda-tech.com/zerothread/1878963
My problem is, when I connect it the right way, it works, but the buzzer is hardly audible. I tried grounding it to the chassis, and it worked! but it stays on when the ignition is on...So either way, it won't work.
Any ideas?
Old Jun 27, 2008 | 10:18 PM
RockinthEFhatch's Avatar
Default Re: Headlight piezo buzzer problem (FieldGenEJ)
Fuse way works every time. Try again.
Old Jun 27, 2008 | 10:19 PM
FieldGenEJ's Avatar
Default Re: Headlight piezo buzzer problem (RockinthEFhatch)
I did. It seems like It's not getting enough power (or ground) to the buzzer...
Old Jun 28, 2008 | 11:25 AM
FieldGenEJ's Avatar
anyone have any ideas?
Old Jun 28, 2008 | 09:00 PM
ef yu's Avatar
you bought the wrong size buzzer?
Old Jun 28, 2008 | 10:05 PM
FieldGenEJ's Avatar
Default Re: Headlight piezo buzzer problem (ef yu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">you bought the wrong size buzzer?</TD></TR></TABLE>
Nope. I tried several buzzers from radioshack...I downgraded to the smallest one(still runs on 12vdc)...but nothing...but when I ground it to the chassis, it works perfectly. It seems like the plug is not getting enough ground...
bleedblue94
15
Dec 31, 2005 11:06 AM
Threads
Aug 8, 2005 05:19 PM
No
Jan 16, 2005 12:54 PM
lude_behavior
Nov 25, 2004 07:10 AM
SaltyHatch
Oct 4, 2003 01:33 PM
